Aardvark
Flight distance : 384432 ft
Planejumper Posted at 2017-10-9 00:01
It sounds to me like you didn't read my post. The DJI Go 4 app detects it as a Inspire, and get's me to install the DJI go for drones before phantom 4.
The solution is really not that difficult. I found a video on youtube that walked me through the process of using both the dji go and dji go4 app to correctly upgrade the firmware on the RC after the failure.
You can only communicate with a Phantom 4 using DJI Go 4, older DJI Go will not work.
The App' sees your aircraft as Inspire 1 because that is the application default, it shows this default because it cannot communicate with the aircraft via the RC to identify which model it is.
Reinstall DJI Go 4 on your display device, for the Nexus 7 (2013) it will be V4.1.9.
I do not know what the reset is now using RC V1.9.3, my old method does not produce any response.
This is the routine to manually relink the RC to aircraft. I don't think this will work with your RC in its current state, but worth a try:-
* Turn on both the aircraft and the controller, wait 30 seconds for aircraft to initialise.
* Press C1, C2, and the record button (top left button) on the controller, then the controller will beep 'D-DD'.
*Let go all fingers, then press the wheel on the right side of the controller (It's a 'click wheel', similar to a mouse wheel) and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds (the button doubles up as LED to left of SD card slot), and then take the pen off the aircraft and wait, it will link soon. LEDs on aircraft and controller will both turn green.
Edit:- I see you have it sorted now
