fans0745d511
Flight distance : 4442 ft
[size=14.6667px]I too have experienced a similar problem. Before I go farther, I have done everything usually suggested...calibration, factory restore, DJIAssitant reload of firmware, flight with app alone (no remote), flight with remote alone (no app), etc.
[size=14.6667px]Mine will track to about 8-9 meters using the proximity sensors (showing the sensor icon next to the altitude), and then, as the Spark rises, the app display will flicker back and forth between the real(?) altitude (without the proximity icon) and something like 8.5 meters (with the proximity icon). Very similar to the video posted above in this thread, but not at 0.5 meters...more like 8 meters for me.[size=14.6667px]
[size=14.6667px]This seems to produce some odd behaviors:
[size=14.6667px]- I can release the sticks while ascending and the Spark will continue to rise at the same rate for a while
- Conversely, the Spark will drop like a rock (possibly faster than it would with the stick all the way down, before the problem) when descending and releasing the sticks.
- At first, I thought the flight log showed the correct altitude, but then realized there was something odd in some of the logs. It seems to only record altitude from the barometer, and doesn't show the proximity sensor altitude. At first I thought "Oh, at least the drone knows its true altitude. Must be the app!", but then.... I had one flight were the "flickering" between altitude sensors stopped at a fairly high altitude, showing only the proximity sensor at 8.5 meter, until it got close to landing. The last barometer reading was at 18 meters. The flight log showed I never went below 18 meters even after landing. To be clear, I took off and landed in the exact same spot.
I'm intrigued at what is causing this, as it seems better on some flights, and terrible on others. I'm guessing that it is one of two things.
[size=14.6667px]- The barometer chip/sensor is failing and the proximity sensor is basically used and reports it's max detection range (8 meters?)
- The proximity sensors are reporting something (falsely) that overrides the barometer reading
I did put a service call in to DJI and they said to send it in (they were very nice), but I'm a curious person and really want to see if there is a solution without sending it in. This would save me, and possibly others, unnecessary time away from their favorite toy...errr...I mean drone.
Anyone else experience the issue? Anyone solve the issue?
