Scarletsboy
DJI Susan Posted at 2017-10-24 01:22
Thanks for getting back to us. Double checked, the drone works well when do not connect with APP, right? Please try to uninstall the APP and delete all related files, then reinstall it again. If still no helps, I suspect the USB port might be damaged, please consider to send it in.
Thanks DJI Susan, i have not put any blades on the drone in fear of crashing it but when i push the stick left and right, up and down the motors spin accordingly I can move the camera up and down as well.
So my question is how can the port be damage from doing a firmware update? noting was touched while this happens, I did not move the drone or the RC at that time.The battery was full and so was the RC half way thru the update the RC LED started blinking and then bleeping and then the app won't work.
As words can be lost in text are you saying that I have damaged the USB port in some way, so they only way to fix the RC is to send this in and be charged for a repair on it?
I had this drone for over 1.5 years it packed away in its case every time it's used, I have never dropped the RC, crashed the drone I am very careful with my stuff, so really not sure how the USB port can be damaged half way doing a RC firmware update? That just does not make sense to me. |
