Hi everyone,
I've had my DJI SPARK for a few months now & with the British weather being typically......... British, there has only been a handful of times I've been able to send my drone up. Each time I've done so though, including a few hours ago...... I don't know what causing it but I'm having the same issues time and time again and it's really annoying.
I have tried both my iPhone 6s and iPad mini 4 to my controller via otg cable. Turn on the app (it does mention something about me not having the latest "flight safety boundary thing".... I can't remember what exactly but I press ignore anyway.) before take off I do have a red escalation mark and also a yellow warning fly zone area but sure enough it takes off fine.
Now......If I'm going slow the feedback of the video footage on my iPad or iPhone is smooth enough (if your within reasonably close distance).... i.e. Up to say 50 metres away, but as soon as you go above this, it becomes very patchy. Literally, regardless if I'm in sport mode or flying slower, the further the drone gets away the more laggy the video feed on my iPad or iPhone becomes....even more so if it's in sport mode. At this point I'm not even at a great altitude, but literally the further I steer the drone away from me, the more and morelaggy laggy/choppy the footage becomes on I've noticed the whole image flickers black and white then looses gps then comes back on again....before finally loosing gps and then returns to home....were miraculously the video feed will then re-appear. I dint know if this is because I haven't got the latest flight path security thing installed (forgot what its called), but I'm pretty it's been doing this since e previous firmware release. I have no pylons or magnetic interfearahce that I know of nearby and there is a red exclamation mark constantly visible on my screen, along with a yellow caution sign saying that I'm flying in a yellow caution area........does this has something to do with it pergaps?? Interestingly despite the feedback and grey / black n white flickering image on my screen, when I have played back the actual recorded footage on my ipad, it looks absolutely fine ??
Just to add..... yes I have video cache switched OFF on both apps, so regardless if I'm using my iPad mini 4 or iPhone 6s....the video cache is a 100% disabled. I did read somewhere you can control the quality of the image feedback on your device that your seeing to a lesser quality but I haven't been able to find this bit....but with that in mind anyway (especially with the iPad mini 4) its got a very fast chip in it, loads of memory space left etc. Using a sandisk 32gb memory card so not a cheap one, and yes I have formatted the card a short while ago. I just find it so frustrating as I'm flying away the drone from me and the picture break up becomes worse and worse, then the screen goes grey and black n white, then pauses , then looses GPs temporarily and auto return to gone inititates and it comes back, the gods ten reconnects and the video footage is resumed ...., albeit very choppy still
