Osee
Flight distance : 530758 ft
DroneFlying Posted at 2017-10-10 02:56
Yes, I was referring to the message in the Go app. However, I don't think that it's indicating that the equipment is "sustaining damage" but just the opposite: that the current is being limited to ensure that it the aircraft doesn't sustain damage, but with the result that it may not be able to do what you're commanding or expecting it to do.
It may also be displayed when the battery is delivering the needed current, but when continuing to do so for an extended period of time is harmful to the battery's long-term performance. If that's the case, then it's not indicating a catastrophic situation but merely a warning that you probably should land or at least find a way to fly without putting so much of a strain on the battery. At least that's my interpretation of the message, but again it's admittedly vague and to the best of my knowledge not clearly explained anywhere. DJI's documentation often leaves something to be desired, but they make the best drones on the market by far.
Now that is the kind of information that I crave - and I hope you are 100 % correct .
If that is the case then I will gladly eat every word that I typed and sing praises to DJI for their excellent protection system in this regard .
However, as optimistic as you are - I am not convinced .
You made me feel better for a minute though - I sure hope you are right .
