Bill Drones
Yes, that is correct. The non-bright areas will be darker, along with the overexposed area of the sky you are concerned about. The only way to get the ground lighter than the sky, without overexposing the sky, is to use a graduated filter, which I'm not sure they even make for the Mavic.
So, to again answer your question, yes, it is possible to capture "super white" as you call it, but you will need to either use a faster shutter speed or ND/graduated filters. |
