Offline Maps bug in GO 4.1.10 for Android
123Next >
7371 99 2017-10-11
Gerd_S.gmx
Flight distance : 4303379 ft
I want to report a further bug within GO 4.1.10 app for Android. Offline maps are no longer working!  First, offline maps downloaded by earlier GO4 version seem to no longer work.  If I then select "Offline Map" from the main menu the app shows a message "Acquiring Offline Citiy List" and then displays a message "Network unavailable" after some time, although the device is online via Wifi connection.  This bug has been confirmed also by other users on drone forums and does not depend on a specific phone or tablet model.
2017-10-11
DJI Thor
Flight distance : 13602 ft
Hi there, I tried my Android device but didn't seem to have the issue, it works for me. Please make sure the linking WiFi is working. If the case persists, please try to reinstall the app. Or provide me with a video which could demonstrate this if still doesn't work.
2017-10-11
Gerd_S.gmx
DJI Thor Posted at 2017-10-11 00:32
Hi,
I have tried with three different mobile devices, two phones and one tablet and have seen the problem with all three in similar way. It also made no difference if I tried it while the Mavic was offline and not connected or while the Mavic was online. I am using a 5.8GHz Wifi network to avoid any interference with Mavic on 2.4GHz. The wifi connection to the internet is stable and reliable, as I use it all the day and have also updated Mavic firmware as well as the Nofly database via this connection before.
Prior to my reporting I had already uninstalled the GO4 app, deleted all DJI folders and then done a clean install to ensure it's really a bug.
If this bug doesn't show up with your device, could it be a country-dependent bug then? I remember an old 4.1.5 bug where the app crashed as soon as the Mavic got a GPS fix due to a string localisation issue.
I am located at Germany.
2017-10-11
Gerd_S.gmx
Gerd_S.gmx Posted at 2017-10-11 00:51
Hi,
Btw. here is a link to others with same problem:
https://mavicpilots.com/threads/ ... .26563/#post-312725
2017-10-11
Jumbo333
Flight distance : 797930 ft
Same issue here
2017-10-11
Ken Huang
My phone is htc M9, it works fine, doenn't have any issue.
2017-10-11
Stolz
Flight distance : 783455 ft
I had this issue a few days ago and I manage to fix it. I'm not sure which of the steps did the trick or if it was all of them. Also, I'm using Android, no idea if it can also work for IOs.
1.- Uninstall DJ Go App 4. If you have the HereMaps Android app installed uninstall it too.
2.- Use a file browser app to remove all the DJI and Here maps leftovers from the internal storage of your phone (directories .here-maps, amap, DJI)
3.- Install DJ Go App 4 from Play store but do not execute it.
4.- Install HereMaps App from Play store and execute it.
5.- Execute Go App 4
6.- Optionally uninstall HereMaps App
Before that I tried steps 1 and 4 separately but it didn't work.
Hope it helps.
2017-10-11
Gerd_S.gmx
Stolz Posted at 2017-10-11 02:12
Tried according your suggestions, installed "HERE WeGo", downloaded an offline map, tried again within GO4. No change to before, still doesn't work!
2017-10-11
Aaronjc
Flight distance : 1194134 ft
Taiwan
if your mobile phone has external SD card ? if yes ,you could try to insert it ,and try it again , it might fix it
2017-10-11
Jumbo333
After several tests, the list of country/region/cities appeared !
2017-10-11
Nelsonlee
Flight distance : 2779203 ft
Malaysia
I have same for my android devices running DJI Go Apps V4.1.10!
Can't download offline maps, it just showing me (Please Wait)....until i sleep also the same!
2017-10-11
Jumbo333
Jumbo333 Posted at 2017-10-11 05:52
But no download ... "Please Wait" ...
2017-10-11
Nelsonlee
Malaysia
Jumbo333 Posted at 2017-10-11 06:55
Yeah.....Please Wait......then keep wait....and till zZzZz
2017-10-11
Anthony566
Flight distance : 2488944 ft
I have the same problem with the latest update for DJI Go 4.1.10 ..... and yes i have removed reinstalled etc etc ......
2017-10-11
Nazar78
Flight distance : 5106037 ft
Singapore
Think there's some sort of glitch on the app or server side? Been using it for few days and only one time today I noticed the Offline Maps menu list gone missing while connected to the AC but the downloaded maps are still there. Didn't really do anything as it seems to work fine though. Then a while ago, the menu is back there again.
2017-10-11
AXP4
Flight distance : 65292 ft
" Please wait " forever.
Tried that on three Android devices already.
I'm in Hong Kong.
2017-10-12
bernardren07
Flight distance : 48504 ft
Singapore
hi to all. i saw u all tried to download and keeping "please wait". i tried to test download but can already. i tried few countries all can. i think in singapore network very high speed so able to download and update firmware my mavic pro as well without any corrupted happen.
2017-10-12
bernardren07
Singapore
Yesterday i updated firmware mavic pro -> remote controller left 81% and 1st battery aircraft left 80% to complete with high network speed wireless at my home. my home router have 2 Gbps.
2017-10-12
gnirtS
Flight distance : 5712575 ft
Identical issue here on 3 devices.  Mediapad M3, Nexus 7 2013 and Nexus 5x
Just hangs on "Please Wait" and doesnt even get that far unless you close the warning about satellite maps at the top.  Cache cleared, fresh installs of the app so clearly something is broken.
2017-10-12
bernardren07
Singapore
can download
can download
download
download
download
download
2017-10-12
Mari
Flight distance : 1308780 ft
I have also problems with downloading off-line maps... first "Aquiring Offline City list"... then "network unavailable"...
2017-10-12
DJI Thor
Hi,
If you have tried different devices and the network is available for sure, I will forward this case to our engineers to look into, I will get back to you once I heard something. Thanks for your feedback.
2017-10-13
DJI Thor
Nelsonlee Posted at 2017-10-11 06:14
Will it be possible the network issue? Please try to reinstall the app, and I'll forward it to our engineers to look into at the same time. Sorry for the inconvenience.
2017-10-13
DJI Thor
Mari Posted at 2017-10-12 11:42
Thank you for your screenshot, is it app also running with the latest version?
2017-10-13
Kannon
Hungary
same problem...  network unavailable Android 7.1.1/ dji go4 4.1.10
2017-10-13
Dutchgixxer
Flight distance : 738084 ft
Tryed again today. Now it is possible to download the ofline maps.  Oneplus 3 Android 7.1.1 dji go4 4.1.10
2017-10-13
Turbotorte
Flight distance : 9885 ft
Same problem on every Android Device I want to fly with.
Can't download the maps on my K1 due to "network unavailable" same on my Note 8 and MediaTab, S6 Edge Plus, etc.
Tested on Android 7.1.1, 7.0, 6.1, 4.4.4.
2017-10-13
Gerd_S.gmx
DJI Thor Posted at 2017-10-13 00:35
Yes, the internet connection is available for sure on all devices I have tested with, working all day with them using my network connection without any problems and with various apps. It's a GO4 app bug, so please report it!
2017-10-13
Kannon
Hungary
Tested xiaomi phone and same problem... 3 different wifi 2 mobil internet... Network error
2017-10-13
Mari
DJI Thor Posted at 2017-10-13 00:56
App is latest version... took some time for it was available
Tested with Wi-Fi and 4G+ connection, in both cases the same result...
2017-10-13
Nelsonlee
Malaysia
Yes, the apps is latest version 4.1.10.
I did many times uninstalled deleted inside folder and download on google play store but it same.
2017-10-13
gnirtS
Issue still present on all 3 of my devices so if its a server problem, its a very very long one.
2017-10-13
DJI Thor
Mari Posted at 2017-10-13 09:38
Alright, I had forwarded to the engineers but haven't heard something back due to the weekend. Will ask the engineers to check it asap. Thanks for your report.
2017-10-14
DJI Thor
Nelsonlee Posted at 2017-10-13 10:49
Noted with thanks. Will have the engineers to check. Thanks for your patience.
2017-10-14
ed.yip
Flight distance : 61854 ft
definitely server or app issue, when i install v4.1.3 again i can download the maps on same network.
similar thing happen to flight record as well, if i dont turn off mobile data and connect to wifi, the maps wont load, if i turn off mobile data and keep wifi on, the map will load.
2017-10-14
Anthony566
I am still unable to download the offline maps.  Samsung S7 GO 4.1.10
But my CS downloads them just fine all via the same internet connection so this is not a network issue as such.
2017-10-17
Blue17
Flight distance : 56010 ft
Same issue here. Nexus 5 Android 6.0.1, DJI Go 4.1.10
"Please wait" forever
2017-10-17
Blue17
Btw, it does work fine with DJI Go 4.1.3, but the maps are gone after the update to 4.1.10
2017-10-17
MARSAN
Flight distance : 966978 ft
Belgium
I have the same problem, but I think this already appeared in the DJI GO 4 version 4.1.9. (Samsung Galaxy S8).
Deleting/reinstalling DJI DO 4 didn't help.
I then deleted all the "here" folders on my phone and somehow it seemed to worked better (not correctly yet) after that.
The Android version of DJI GO 4 is full of bugs and only held together by kilometers of duct tape.
2017-10-18
Tangcmin
Flight distance : 5217 ft
Malaysia
I have same problem with this.
I am using Samsung S8+ and  DJI Go 4 (4.1.10)
2017-10-18
123Next >
