2.4 and 5 Ghz - DJI Phantom 3 SE
12Next >
16931 53 2017-10-11
snacky
Flight distance : 35623 ft
hi,
is there a way to change the frequency for this drone?
i see the setting under Wifi, but changing and saving it's not doing anything...
2017-10-11
Mark The Droner
Flight distance : 2917 ft
No
Edit:  Actually, YES.  Keep reading below.... and watch the beginning of the 2nd video...
2017-10-11
Nelsonlee
Flight distance : 2779203 ft
Malaysia
NO?!
Are you sure!
2017-10-11
Nelsonlee
Malaysia
Please look my video here for the reference.
2017-10-11
Mark The Droner
Could you give me a summary?
Edit:  I just watched video 2.  It appears you are correct!  It appears one can change the wifi freq from 2.4 ghz to 5 ghz on the SE.  I had no idea this was available!  Thanks for the info!
2017-10-11
Nelsonlee
Malaysia
Mark The Droner Posted at 2017-10-11 06:37
You are Welcome Sir.
2017-10-11
Spacer2711
Flight distance : 821821 ft
It would be very nice if this option is also available for iOS.
2017-10-11
snacky
hi, I see the same options to select 2.4 or 5
how to check which one is operating?
wifi is still definitely 2.4 (this is what android is showing in wifi details)
or that frequency only for dron<>remote ?
2017-10-12
Nelsonlee
Malaysia
Spacer2711 Posted at 2017-10-11 12:04
IOS is also have this option but i dunno why my Ipad doesn't show up to me, i saw other pilot they can showing that.
2017-10-12
Nelsonlee
Malaysia
snacky Posted at 2017-10-12 09:28
Your phone must have WiFi 2.4g and 5g support, older phone is only have 2.4g wifi.
2017-10-12
DJI Susan
The RC of P3 SE support 2.4 GHz and 5.8 GHz. I would recommend you to change to another recommended mobile and try again.
2017-10-12
Siambuddhas Gro
Flight distance : 116926 ft
Singapore
A very good explore....
2017-10-13
snacky
Nelsonlee Posted at 2017-10-12 17:37
have that, but selecting and restarting WIFI doesn't change anything
phone still showing it's using 2.4Ghz
2017-10-13
snacky
DJI Susan Posted at 2017-10-12 23:35
hmm. ok so the problem is that listed recommended devices are just few what's on the market
i don't have any to be honest, maybe someone who has officially supported  device can check if frequency can be changed
look at you wireless details after on your mobile, it should show what freq is used
2017-10-13
Mark The Droner
Don't confuse the 5 ghz wifi signal with the 5.8 ghz control signal.  They are two different signals and use two different frequencies.  Also, note that the 5 ghz wifi option is not mentioned adequately in the specs page.
http://www.dji.com/phantom-3-se/info?lang=cn#specs
Nonetheless, 5 ghz FPV is an option as shown early in video #2 in post #4 above.
2017-10-13
fans8b8b625f
Flight distance : 1074380 ft
Argentina
I have a question on the Phantom 3 Special Edition Remote Control and a Phantom 3 Standard Control. They Look the same but are they Compatible.  I need a Phantom 3 SE replacement control and don't know if the Standard edition one is compatible ... Thanks
2017-10-13
Nelsonlee
Malaysia
fans8b8b625f Posted at 2017-10-13 09:06
No, Phantom 3 SE remote control is not compatible for Phantom 3 Standard, same the Phantom 3 Standard remote control is not compatible for Phantom 3 SE.
2017-10-13
ACW
Flight distance : 13926112 ft
Nelsonlee Posted at 2017-10-13 10:47
Thats surprising as hey both use wifi - may be this will be updated in the future.
2017-10-13
Mark The Droner
The SE controller is much more advanced over the Standard.  The transmitters are considerably more powerful, the SE has the ability to switch to 5 ghz wifi as mentioned above, it has the ability to receive and relay a much higher quality FPV signal, so even if they were somehow compatible, it would be silly to handicap your SE so severely by forcing it to fly with a controller that was designed two years prior.
2017-10-13
DJI Susan
snacky Posted at 2017-10-13 00:42
The performance can be ensured for recommended mobile. We will add more mobile devices as  testing and development continues. Appreciate your patience.
2017-10-15
DJI Susan
The controller of P3 SE and P3S are not compatible. We will release on our website if more news is available.
2017-10-15
djiuser_EELX5PJ
Flight distance : 509797 ft
Croatia
Hello Nelsonlee,
well, for me and my equipment the answer is NO.
After switching from 5.8 to 2.4 in DJI Go, my Phantom 3 SE disappear from WiFi list of my phone.
Tried that with my MEIZU MX5 and SAMSUNG Galaxy  9.7 - those devices both have dual band WiFi.
Despite that, RC is still in control of the drone (I can control the gimbal).
I live in EU so CE regulations kicks in, further more I cant switch to 2.4. I'm so disappointed at the moment. Further more, P3 SE is new on the market and still no way to switch to FCC as far as I know
Just purchased ARGtek antenna system. But this will just a slight improvement because of the weak, weak Tx signals.
So, this is how I see it. Spent the very same amount of money as guys within FCC, but got a far less.
Bottom line is, if I buy Mercedes, I really do expect to have a full potential out of it, not  a car with 1000ccm.
2017-11-12
VonMacher
Croatia
DJI Susan Posted at 2017-10-15 00:56
Hello DJI Susan,
I kindly ask you to make some things clear.
How that P3 SE WiFi work since it is dual band?
For example, when indicated on DJI Go that it works on 5.8 GHz, what is 2.4 GHs link doing at that time? Just communicating with mobile device? That would mean both video and controls goes through one band link. Am I right or completely wrong?
Thanks for your kind answer...
2017-11-12
StoyanK
Flight distance : 68963 ft
Bulgaria
VonMacher Posted at 2017-11-12 00:31
Hello DJI Susan,
Following....
2017-11-16
DJI Susan
Hello DJI Susan,
When the APP indicated 5.8 GHz in DJI GO, it means that the image transmission and RC signal between aircraft and RC are 5.8 GHz, while the working frequency between RC and mobile device are 2.4 GHz.
2017-11-17
Mark The Droner
DJI Susan Posted at 2017-11-17 00:51
This is news!  I did not realize this.
Something occurs to me.  I wouldn't be surprised if the FPV/telemetry signal that transmits from the AC to the controller is actually a lightbridge signal.  And it is then converted to wifi and sent to the mobile device.  This explains the significantly longer distance than the (other) wifi Phantoms without a significant change in transmitter strength or antenna, and also explains the long distance HD FPV capability.
2017-11-17
Zippo43
Flight distance : 387126 ft
Mark The Droner Posted at 2017-11-17 03:40
Mark......hope that we hear that this what go's on and thats why it has a much farther range !   hope that Susan will let Us all know....i'm waiting !
2017-11-17
VonMacher
Croatia
Yes, this make sense.
So P3 SE is nice hybrid between P3S and P3A/Pro.
Why don't they use DJI Go 4 app than?
2017-11-17
Mark The Droner
When the APP indicated 5.8 GHz in DJI GO, it means that the image transmission and RC signal between aircraft and RC is 5.8 GHz, while the working frequency between RC and mobile device is 2.4 GHz.
I have another question, please.  When the app indicates 2.4 GHz in DJI GO, does that mean the image transmission and RC signal between aircraft and RC is 2.4 GHZ?  Thank-you.
2017-11-17
VonMacher
Croatia
One more thing to ask... In DJI Go 4 App HD settings there is a possibility for Automatic/Manual frequency change and viewing channels interference, so it gives you a chance to choose the best channel.
In DJI Go App in the other hand, it is not possible to choose Automatic/Manual frequency change, neither channel interference are visible. Is this normal for DJI Go App (maybe to be implemented later), or something went wrong with my installation?
2017-11-18
Mark The Droner
I am pretty sure it is normal.  The P4 has quite a few capabilities that the lower Phantoms don't have.
2017-11-18
Nebuchadnezzar
Flight distance : 3462946 ft
Im using Phantom 3 SE with my Huawei Y635-L01 8GB/1GB ram and it show im running in 5.8 GHz . always
2017-11-21
DJI Susan
Mark The Droner Posted at 2017-11-17 18:43
You are correct.
2017-11-24
djiuser_kTrYeGg
Flight distance : 503983 ft
Same problem for me since the last update when I switch between 5 to 2.4 the dji phantom disappears of the wifi list!
And now I just can fly at 100 meters instead of 1.5 kilometers before the update!! Change it I haven't payed 600 euros to fly 100 meters!!!
Thanks
2017-12-9
djiuser_kTrYeGg
Dji has to know that it is unacceptable! so put commments as me on dji site
https://facebook.com/commerce/products/1302716619857450
2017-12-9
Spacer2711
I think I have a solution. I regret that the android users are confronted with a limited distance. This problem does not occur when you use an Apple tablet or phone. And for the following.
Within Europe the 2.4 ghz band for Wifi is overcrowded. European guidelines therefore indicate that it is preferable to use the 5 ghz band. Within Europe, the distance between the drone and the remote control is therefore 5 ghz. That means that your phone or tablet on the 2.4 ghz band has contact with the remote control.
So, if you want to change the above situation, then you need to install an app on your phone / tablet that will prefer to connect to 5GHz Wifi networks instead of 2.4GHz networks. You will first have to establish a connection between your phone / tablet and your remote control. When you last switch on your drone, it will connect to the available band (2.4 ghz). To "force" your phone using the 5 ghz band, there are several apps available.
2017-12-10
Nebuchadnezzar
Thanks for share this info !!
2017-12-10
Nebuchadnezzar
2017-12-10
djiuser_kTrYeGg
For me it doesn't work sorry have you find a solution?
2017-12-18
Microcyb
Flight distance : 1095955 ft
Yes and no.  Yes, but you have to modify your drone and void your warranty completely, and No because we cant talk about that anymore as we get in trouble in this forum.
2017-12-20
12Next >
