Max Limit reached Problem!
1497 11 2017-10-11
SAFAERIALS
Flight distance : 93146 ft
Dominican Republic
Hello,
Today a flew my inspire 1 after a while, It has all the updates done and the app is up to date, when I started flying I could't fly more than 30m away, even though in the app I had the range at 500m and 250m altitute limit, I got the alert of maximun distance reach.
What could be going wrong?
Thanks in advance
2017-10-11
When you encounter this problem during flight, please hover the drone to open safe place and reboot the APP or return the drone back to home point and reboot the APP.
Please remember to reboot APP after powering on the aircraft when you change the battery.
2017-10-11
Highasakite
Flight distance : 1423930 ft
SAFAERIALS, you need to log in to your DJI account on your device, then you should be good! Safety First! Ken.
2017-10-12
SAFAERIALS
Dominican Republic
DJI Mindy Posted at 2017-10-11 20:27
Thanks! I will try this today!
2017-10-12
SAFAERIALS Posted at 2017-10-12 05:29
Not problem, thanks for your time.
2017-10-12
Flire8
Flight distance : 2546572 ft
Czechia
DJI Mindy, please, when DJI resolve this persistent problem??? The first complaints are from August. Now is October and there is still no solution from DJI? It is very annoying to end the application every time you replace the battery !!!
2017-10-12
Flire8 Posted at 2017-10-12 23:50
I understand, really sorry for the trouble caused. We've got the news it will get improved in the next APP, but don't have the date, please wait patiently for the release, thanks.
2017-10-13
Highasakite
Flire8, you don't need to exit the app, just land the aircraft let the rc and app running, turn off battery, when the app goes dark and says aircraft disconnected, just go back to the home screen. it shows your aircraft and from there you can install a new battery, turn it on and it will connect as normal, no problem! Safety First! Ken.
2017-10-13
Håkan K
Flight distance : 262946 ft
Sweden
Highasakite Posted at 2017-10-13 01:42
It happens without changing battery too I noticed last weekend taking off for the first flight that day.
2017-10-13
SAFrankSU
This happens to me too, but I always get around it. Simply land the drone, turn your controller off and back on. That always seems to do the trick.
Double check your remote/drone settings when you're in the app. Sometimes the "max" distance limit is reset.
2017-10-26
SAFrankSU Posted at 2017-10-26 17:29
We suggest to update your DJI Go to the latest version.
2017-10-27
SAFAERIALS
Dominican Republic
DJI Mindy Posted at 2017-10-27 01:36
I have everything up to date and still having the same problem, can fly more than 50meters away from home point. Any suggestions?
2018-2-14
