15matjan
Flight distance : 1158258 ft
DJI Thor Posted at 2017-12-15 19:23
Hi sir, for the sync question, could you please help to confirm if the records all have little cloud behind? If they do not have, please try to use another network to try, or could you please provide me with your DJI account and export the records that are not synced? I will forward to our engineers to check. Below's the route.
For the location on the forum, it depends on the IP of your last reply, if you are travelling Finland now, then it is normal.
For the map loading, it might because the geocoder does not answer every request in the same way. Instead, the first requests from a certain device are answered quickly, but if the device has sent say 100 requests or more, the answers arrive slower and slower or requests are not answered at all, which might cause MapLoading for a couple of days.
Finally I managed to sync all the flights when back home.
Below's the route.
DJI GO starts to request those MapLoading record when launching or clicking on the record so that some records will show the place name after a few days.
But noted that Maploading with not be recovered if the takeoff position has no or weak GPS signal.
I had good GPs signal always. After syncing I managed to have the RC+ showing the map position for 2 of the 17 videos with "map loading" issues.
At a certain point system prompted NETWORK UNAIVAILABE, it was yours, because, mine was OK and, I lost the map position of the 2 videos I managed to have "map loaded" before...At home I have a 500 Mbps connection, what should be done to manage change from "Map loading" to map position ?The result seems to be also not having updated my flights on my forum's page&profile despite of having then already synced...
And for the city of the flight path, it is because the map needs to initiate, so when you start the record, it will show the right location. No worries.
For the record, we recommend syncing all.
For the resume page, the first page is the total of your data. The second, third or more will be the respective drone that you own. So they are not the same.
I knew that. But I have a first total page, then a resume page of the P3A I previously owned and flown, a resume page of the P4P+ I currently own and another resume page of the same P4P+ I own with only one flight which appears on the total page but it does not appear on the 3rd page (with all the other flights of P4P+). Which is strange and annoing as I do not need to generate randomly pages for any of the flights flown with the same AC.The GPS signal during those flights was always good.
Below's the flight record file route:
For Android devices, connect the device to the computer, find the flight records stored in …/sdcard/DJI/dji.go.v4/FlightRecord/SyncResult, and copy the required flight records to the computer.
Mine is a P4P+ with built in screen.
Thanks
Thank you for your help.
