Today, I’ll tell you more about the 18000mah 6s, which is the updated version of our TATTU Pluse. Tattu pluse 2.0 smart battery. It’s specially made for agriculture spraying, aerial photography survey drones and maybe your DJI 1000& 1000+. Because of the stable discharge curve and super large capacity, it provides you long enough flying time for most of the tasks. It has 6 cells, it’s a quite large battery in terms of the 18000mah capacity. Comes with 15C discharge rate, with max burst discharge rate at 30C. The discharge plug used here is the AS150 + XT150. It comes with a smart casing. Weighted at 2270gram.
Let’s look at some features. The Tattu plus 2.0 smart battery has overheat , low temperature, over voltage and over current protection. Another cool feature is that it has intelligent storage function. There are many upgraded functions on this battery comparing to the first generation. For example, the new LED system has replaced the LED flash warning, 4 LEDs on the side are the charge level and battery cycle life indicator. By pressing the power button for different time length, you then know how full is your battery has been charged and even how many services this battery still lefts. If short press for 1 sec, it will show battery charge status.And if press for 5 seconds: Display the remaining cycle life of the battery Besides, for these three LEDs, it has different features. When your battery is unuaual, red light will turn on. When the middle LED light in orange, it means you need to charge the battery as soon as possible. Lastly, if white LED lights up, it means the battery is not suitable for storage. And it will active the protection mode automatically. In this new version of the Tattu plus battery. A brand new design has been applied to the outer case, making the battery more safe and sturdy in different scenarios. We have add in two battery to battery/ battery to drone connection ports, ensuring the battery is safely mounted on your drone. The Foldable handle for easy disassemble and carrying around. So this is the brand new Tattu plus 2.0 battery. They are now available on our US and EU online store. For more information please check out the links below.
