KeesJ
KeesJ Posted at 2017-11-19 11:20
Finally, after 30 hours of tying, everything is in order now with the firmware. That is, I still have to fly it (it's night now) but all connection problems seem solved.
After all it was NOT the cable, nor the phone, nor the installation of DJO Go4, it was just that there are so many things you have to pay attention to, and if even a single one goes wrong, you do not have a connection or your app does not automatically recognize the phantom 4, or you have no camera image in your app.
FLY UPDATE.
Today I flew the phantom bird after the firmware update to beta 0600. I can confirm that many of the prob;ems are solved. Before the beta ((firmware 2.00.0106) my P4 was jumping up and down as soon as I took off, and I had to land asap which was rought. I crashed a propeller but there was no other visible damage. So I mounted my reserve props and with beta 0600 and DJI Go4 reinstalled and adjusted, was able to fly it rather stably. P4 kept its position very well, although I only flew les than 10 feet high (didn't quite trust it yet). The only thing then I noticed, is that the P4 seems somewhat nervous about crashing into something. I have flewn many times in my small yard, and it used to be able to go in small spaces, as long as the forward camera did not see a close hindering opject. This time, P4 refused to listen to the sticks unless it was in a clear open space.
Is this new behavior or is it just not good enough?
Best regards, and again, thanks for your help.
Kees |
