RicardoGray
Flight distance : 4356421 ft
The switch is in the correct position as Solentlife suggested. If you go outside and there are absolutely no bars showing at all, you may have a faulty GPS, or the wires may have come loose from the main board. Have you had a hard landing recently? I would remove the top shell, and carefully look to see if the wire coming from the GPS is plugged securely into the main board. Your GPS module sits in the top of the upper shell. If everything looks ok, your best option might be to send it in. |
