Geebax
KedDK Posted at 2017-10-13 02:18
Hi Geebax
I know you have a lot of knowledge regarding those things, but somehow it must know something about sea level as the "Top Altitude" from Flight Stats seem to refer to this value?
'but somehow it must know something about sea level as the "Top Altitude" from Flight Stats seem to refer to this value?'
I have no idea how DJI calculate 'Top Level', it always seems to be wrong anyway, so I ignore it. But the aircraft has no idea where 'sea level' is. As I stated earlier, it uses a barometric pressure sensor to measure its altitude, just like a real aircraft does, so it only knows its altitude above the take-off point. This is because it resets the altitude to zero when you start the motors.
'Not that i know of the US rules but i would suppose that the 400 limit would be relative to ground level and not take off level so actually one is supposed to descend as ground get lower if tex. taking off from a mountain, is that a wrong understanding i have here?'
The 400 foot limit is relative to the ground you are flying over, and in certain circumstances, relative to a structure that rises above ground level.
'I think that if taking off from a very high point and raise to your 400 limit and take to all i can reach of distance you would be way to high or ?'
If, for example, you took off from a point 100 feet lower than the summit of a mountain, you can then fly upwards 500 feet so you are now 400 feet about the summit. That puts you at 400 feet AGL ( Above Ground Level).
