Battery Signal Error
13482 30 2017-10-13
alexPhant
Flight distance : 475384 ft
a few days ago i unpacked my new phantom 4 pro. i updated everything nicely and took off, during flight the dji go 4 app sometimes says i have a "Battery Signal Error".
Can anybody please help me with this issue. Its really frustrating since ive already had a problem with my very first P4P, i had to send in because of a body shell crack. Now i have this drone with other problems
i appreciate any help
thabks
2017-10-13
DJI Susan
Does this battery have been updated with the aircraft? If yes, please try to drain the battery and recharge it fully to check whether it is the misinformation.
2017-10-13
DJI Elektra
Alex, please follow susan's advice. In addition, you can try to update your drone again.If the error message is still here, please contact our support and start a case: http://www.dji.com/support.
2017-10-13
ALABAMA
Flight distance : 10442687 ft
Were you sent back a brand new drone?
2017-10-13
alexPhant
YES
2017-10-13
RicardoGray
Flight distance : 4356421 ft
Follow what has been suggested, although it is a shame you are having these issues. Do be careful though. I wouldn't get too far with any type of battery error showing. Would hate to see the thing fall out of the sky!
Good luck to you.
2017-10-13
alexPhant
@DJI_Susan
all i did was upgrade the drone in the go app, doesnt that also update the battery?
2017-10-13
RedHotPoker
Flight distance : 165105 ft
alexPhant Posted at 2017-10-13 10:15
@DJI_Susan
If the battery needs to be updated, you will certainly get a battery error message in the app.
Have you checked in the app under About, which firmware versions you currently have installed?
RedHotPoker
2017-10-13
alexPhant
app: 4.1.10
aircraft: 01.04.0608
Remote: 01.04.01.00
2017-10-14
alexPhant
theres no information  about the batteries firmware
2017-10-14
alexPhant
so how would i upgrade?
2017-10-14
DJI Elektra
alexPhant Posted at 2017-10-14 00:33
Alex, you can watch this video and upgrade your AC again through DJI Assistant 2.
2017-10-14
alexPhant
well, i did a factory data reset and now i wanted to upgrade the latest firmware, but it says '' cannot load firmware list''
2017-10-14
Woodwanger
alexPhant Posted at 2017-10-14 02:08
Try Closing the app and restarting it
2017-10-14
alexPhant
i have done that at least a thousand times
2017-10-14
alexPhant
btw this was in the assistant2
2017-10-14
DJI Thor
Flight distance : 13602 ft
Please try to shut down the application and the drone, restart your PC and reconnect again, if it still doesn't work, try to reinstall DJI Assistant 2 to see if it helps to load the firmware.
2017-10-14
alexPhant
thank you @DJI Thor
it worked now since i installed the application directly from dji.com
2017-10-14
alexPhant
i ll keep u guys up to date
2017-10-14
alexPhant
hope that solves my main problem thou
2017-10-14
RedHotPoker
alexPhant Posted at 2017-10-14 06:56
Hahaha, another happy customer. I love it.
I wish more satisfied pilots here would be having success stories to share today..
RedHotPoker
2017-10-14
RedHotPoker
As long as you have all current firmware, your battery should already be uptodate.
RedHotPoker
2017-10-14
alexPhant
So after a bit of flying around, i noticed the false message still appears sometimes, even after  i tried it with two different firmwares and two batteries.
its a shame, but ill be sending this drone for exchange, just because because of this stupid message...
One positive thing though! the last repair/exchange only took one week, so i will hopefully be flying again soon.
thank you fellas for supporting me
fly safe!
2017-10-15
RedHotPoker
alexPhant Posted at 2017-10-15 11:06
Oh it was nothing, really. Hahaha
Hope all your wishes come true. New drone.
Have fun, happy flying, enjoy those landings...
RedHotPoker
2017-10-15
alexPhant
Why is dji not listening?
I just got an email that they would exchange the battery, but thats not the Problem. The Error is caused by the Aircraft and not the battery, since i have two batteries and both show problems with the drone
2017-11-8
alexPhant
If that is the case i will have to send the drone in for the 3. Time! I just wanna let you guys know, i am going to keep doing this until i get a fricking functioning drome
2017-11-8
Edugarcya
Flight distance : 4399495 ft
Brazil
Olá amigos!
Estou com um problema no meu Mavic 2 Pro.
Há cerca de 3 meses comprei duas baterias, novas!
Uma delas está funcionando perfeitamente...a outra, voei 4 vezes apenas a apresentou a seguinte mensagem: "BATTERY SIGNAL ERROR. ENSURE THAT YOU BATTERY IS PRODUCED BY DJI AND CHECK THE BATTERY CONNECTION. CONTACT DJI SUPPORT IF THIS PERSISTENT..."
Pois bem...realizei a troca a muito custo e com uma demora de 2 meses e meio.
A nova bateria chegou essa semana. Fiquei extremamente feliz pois só estava usando a mesma sempre!
Voei apenas uma vez ontem e fui ligar ele agora pela tarde e a mesma mensagem aparece!! Estou muito chateado, pois o drone LIGA, porem nao funciona. A batteria tem todos os dados em branco...como se não exitisse. Já tentei todas as formas de reparo via DJI ASSISTANT 2 mas nada resolve. Alguém saberia de alguma outra forma?
A bateria é NOVA!
aMBAS VIERAM COM "0 CILOS" !!
Obrigado..
2020-12-16
Edugarcya
Brazil
Seguem as fotos:
2020-12-16
Edugarcya
Brazil
2020-12-16
Edugarcya
Brazil
2020-12-16
Edugarcya
Brazil
Agradeço qualquer ajuda...
2020-12-16
