fans7c0423f7
Flight distance : 641407 ft
It would appear that my gimble might have something loose? Maybe. the unit is brand new. but only 50% of the time when I turn it on does the gimble work correctly. 50% of the time it has no video transmission and no SD card data. But the unit flies so it is connected. I can then power it down and the battery circle light flashes and it takes longer than normal to shut down. Then I reboot and everything is fine...
What do you guy think?
I was wondering if I could flash the firmware. Or maybe remove the gimble and reseat all the connections.
