sonnavindDF
Flight distance : 288875 ft
Norway
DJI Thor Posted at 2017-10-13 08:16
The altitude shows on the app is the relative altitude of the takeoff point. For the influences, as for what I can tell now are the following: pay attention to the return to home altitude that you set, it is also the relative altitude of the takeoff point, don't mix that and thought it might be the total altitude the drone will fly; intelligent flight modes can not be used when the app showing a negative value.
For the flight and the drone it self, it doesn't seens to have negative influences. No worries, but fly safely.
Tanks for your reply.
So if I understand it correctly, e.g., i start flying from a point 20 meters above sealevel, have the RTH height set to 30. I fly "down" to 10 meters above sealevel and lose connection. The p4a will then rise 40 meters in total height, to achieve the 30 m RTH height correct? |
