X7 Lenses more focal lengths available?
1791 6 2017-10-14
Skyris
Flight distance : 333799 ft
Just wondering if there will be more lenses available in the not too distant future, reason I ask is that I tend to need different focal lengths to suit clients needs, 16mm (35mm equiv) is a regular one for architecture photography.
I would love to upgrade to the X7 for higher res but the available lenses are a bit of a worry.
2017-10-14
DJI Elektra
Skyris, what is the specific lens you wanted? I can forward your suggestion to our engineers. Here is the available lens now:
DJI DL-S  16mm F2.8 ND ASPH
DJI DL   24mm F2.8 LS  ASPH
DJI DL   35mm F2.8 LS  ASPH
DJI DL   50mm F2.8 LS  ASPH
You can also check it from our website: https://store.dji.com/product/ze ... m=search-result-v2.
2017-10-14
Montfrooij
Flight distance : 2560453 ft
DJI Elektra Posted at 2017-10-14 01:43
Thanks for that!
2017-10-14
Drone Trilogy
It would be great to see longer focal lengths, like an 85mm or 100mm on the X7.  I love the Olympus 45mm(90mm FF equiv) telephoto on the X5s to get long fast sweeping shots, not to mention the f/1.8 aperture.
2017-10-14
rbendjebar.mac
Flight distance : 3170190 ft
Drone Trilogy Posted at 2017-10-14 07:40
There are two tech challenges to creating longer focal length lenses: keeping the same 2.8 f-stop with a longer focal length (why fast telephotos are usually heavy with lots of glass) and stabilizing the lens with a narrower field of view. As it is, the 50mm DL lens has a 35mm equivalent focal length of 77mm in wide view and 85mm in narrow view. That will give you a moderate telephoto perspective, which you can always increase by cropping into the frame (6K>4K, for example).
I expect that there will be further long  or zoom lens choices available, but the constraints are weight (=flight time)  and gimbal stability.
2017-10-14
Skyris
I would love to see a wider focal length than the 24mm eq. Maybe a 10mm to give 15mm eq.
2017-10-14
DJI Elektra
Trilogy, thanks for your attention. I think longer focal lengths is great, too.
2017-10-14
