Daroga
Flight distance : 3517287 ft
The default setting for video transmission is AUTO. But the setting is configurable to best meet the flight environment you are operating within.
For Inspire 1 aircraft control surfaces, sticks, buttons, etc, DJI uses a 2 MHz wide frequency-hopping spread spectrum modulation between 2400 and 2490 MHz.
For video, DJI uses 10MHz wide channels that originally spanned 32 channels from 2280 to 2600 MHz. Later, DJI discovered that only 8 channels (13-20) were legally available across the various regions. (The lower 12 channels are Satelite/Space freqs and the upper 10+ are Sprint LTE freqs!). So today, the DJI GO App provides AUTO or Custom and only uses 8 channels. NOTE: For aircraft that use the DJI GO App (P3, P4, and Inspire 1), there is a modification that will expose the original 32 channels see this Forum Thread for additional information -> Change DJI Remote from 8 to 32 channels...
For clarification, the RC and aircraft only use 2.4 GHz channels. The 5 GHz frequecis are only used between master and slave RC units when dual operator flights are conducted. As with FHSS control surface methodologies, for video, DJI followed suite with AUTO which programmatically uses the least congested channel between 13 and 20 and uses that channel. During flight, AUTO will allow the software to switch channels if freqency congestion occurs.
Since the eight 2.4 channels share the wifi spectrum, many localities use wifi channel 1 and 6 which overlap DJI channels 13 & 14 and channels 16 & 17, so many pilots will select custom settins and use the higher channels if their locality has less congestion. The GO App provides a graph that show the current congestion -> the higher the graph bar, the greater the congestion. So you're looking for the lowest bar on the graph!
Which settings are best totally depend on you, your environment, and pilot skills. AUTO is a no-brainer, but be prepared for the occassional frequency shift inflight with video breakup. Custom, manual selection, puts you in-charge but does not change unless you change it....
