DJI Thor
Flight distance : 13602 ft
If it is the environment issue, when the drone can not detect the GPS signal, it will switch to ATTI mode passively. For the most cases, if the drone suddenly turns to no GPS signal, it might due to the signal shielded, compass interference, or interference region like military region, and it is the GPS module's error. When it suddenly comes to ATTI mode, if it is possible, you can try to ascend the drone to see if it regains GPS. |
