jonlee0483
Thanks for help folks.
OK followed these instructions for saving a map ...
3. Find map area I want
4. Pull up the place info sheet at the bottom of the screen, and touch Save map to use offline to save the selected area of the map.
save map to use offline button image
5.Only what's on the screen will be saved. Adjust the map by moving it and zooming in or out, as needed, then touch Save.
6.Name the map, and then touch Save.
7.After a few moments, you'll see a message confirming that the map area has been saved.
There is no map info area at bottom of map on my device scree,
But found Save in a different area, so clicked on Save.
Does not ask me to name the map.
Do not get confirmation that map is saved.
AND, no map appears in DJI Vision app Ground Station, just a blank area. No change.
So what else can I try?
JonS |
