geoffz
Flight distance : 1941322 ft
DJI Thor Posted at 2017-10-15 23:20
The obstacle avoidance will be initiated when the drone is flying towards the sun or a strong light directly, it is the Visual System which activates the beeping and brakes the drone, it is not about the mobile device system.
And for the disconnected, please check if it is the app's disconnected or the transmission signal lost, you can try to adjust the antennas if it is the transmission signal lost. Then check if it is the loose contact between the male and female port.
BTW, please update the firmware of the Crystalsky to ensure the performance. Thank you.
Activating the OA braking when flying forward towards the sun, in normal mode, is unacceptable performance flaw and should be remedied.
To have to disable OA to counter this fatal flaw is adding fuel to the fire. The craft then flies faster and is more difficult to control.
To answer your question, I've never incurred a loss of transmission. When I receive a weak signal warning, I increase altitude/change course.
Therefore, the Crystal Sky disconnects the app.
The screen goes completely dark
Finally and most alarming, there's no method to reconnect the Crystal Sky monitor to the craft.
And...yes, the latest CS firmware is installed.
I surmise it's the unstable Android open source Go4 app that is the main problem.
Why DJI went to Android is baffling but probably they didn't want to pay Apple license. |
