Wide angle lens
5000 8 2017-10-15
BASE509
Flight distance : 2503 ft
Has anyone used it can recommend a good wide angle lens for the mavic pro? Does anyone have an opinion about using a wide angle lens? Some of the shots I’d like to get would be better if I could get more in the frame. Just a thought. Thanks
BASE509
2017-10-15
Brokenphones
Flight distance : 489400 ft
The lens on the mavic is fixed, not interchangeable, with a 78º field of view. It is already wide angle.
2017-10-15
StanfordWebbie
Flight distance : 178018 ft
The Mavic does support changing the view from landscape to portrait, but that would go in the other direction from what you're asking.
2017-10-15
Montfrooij
Flight distance : 2560453 ft
Too much glass to add.
That would make the gimbal go crazy.
Composition is way more important then 'getting it all in the frame'.
At least, so they say
Then again, you can always fly up and back a bit and achieve the same right? Just like I do with my prime lenses
2017-10-15
djiuser_larry
Flight distance : 70200 ft
There are a lot of programs and apps that can stitch pictures into a panorama. I usually use Lightroom but you can probably find other cheap or free open source programs like GIMP. Just go up and take a set of sequential shots and see if you can overlap them.
2017-10-15
Montfrooij
djiuser_larry Posted at 2017-10-15 11:25
That would opt out video of course.
2017-10-15
BASE509
Ok. Thanks guys
2017-10-15
ACW
Flight distance : 14044577 ft
Use DJI Media Maker for stitching panos - works really well.
2017-10-15
DJI Thor
Flight distance : 13602 ft
Yes, like 2# mentioned, Mavic owns FOV 78.8° 28 mm (35 mm format equivalent) f/2.2 lens, it is already the optimized version with its own design. We don't support modifying the lens. Thanks for the understanding.
2017-10-15
