Paul Tomo
Flight distance : 607336 ft
DJI-Jamie Posted at 2017-10-18 13:42
Just to reiterate some of the info already provided by others, you'd want to ensure that you always use the appropriate screws when installing, dismantling, and vice versa. Prop guard screws, whether from the DJI prop guards or aftermarket ones, are longer than the stock screws for the motors. If you take off the prop guards, you always want to ensure you put the stock ones back on. If you don't you're risking screwing right into the motor and damaging it when you screw in all the way. That kind of damage is always considered a non warranty situation.
Thanks Jamie,
Shall I leave the screws that come with the prop guards and only use the ones I take off the drone then, is that what you are saying. I see in the description from the guards that I'm buying that there are 4 screw holes per guard yet the DJI guards only have 2 holes so may be I should wait and buy the DJI guards?
Last thing I want to do is cause any damage. |
