Kneepuck
Flight distance : 275105 ft
The only time and reason to calibrate is if your Phantom does not fly normally. If, in P mode while hovering or flying in a straight line, the Phantom turns or spins or otherwise deviates from your chosen direction, then calibrate. IMHO. The reason is because, once you have a good calibration, you risk messing it up the next time you calibrate. Nearby ferrous objects, etc. can ruin the calibration. Steel reinforcement rods in concrete or even roads or driveways. Steel that you can't see. But if you have a good calibration, even if it acts strange at first, once you fly away from magnetic interference, the drone will likely behave normally. IMHO.
