NO SIGNAL when I connect drone at computer
1195 11 2017-10-16
Maurxzy79
Flight distance : 227375 ft
I try to connect drone-pc and appears NO SIGNAL, I disconnect the cable and disappears NO SIGNAL.
Is it normal?
My phone is certified Honor 8 and Enabled Developer Option
2017-10-16
DJI Susan
Just to verify, are you trying to connect the mobile, instead of PC, right? I would recommend you to re-install the APP, restart the aircraft and controller again to see whether it helps.
2017-10-16
Punchbuggy
Flight distance : 483166 ft
You cannot establish a link between the RC and craft when the craft is connected via USB to your PC. Is that what you meant?
2017-10-16
Maurxzy79
Punchbuggy Posted at 2017-10-16 20:44
The RC is connected because I can move gimbal, but the image on the phone is "locked" and grey.
2017-10-16
Maurxzy79
DJI Susan Posted at 2017-10-16 19:53
No I turn on the drone, turn on the RC, they connect correctly, then I connect drone with PC by USB cable to download photo and video and appears NO SIGNAL with grey image blocked.
2017-10-16
Kneepuck
Flight distance : 275105 ft
Maurxzy79 Posted at 2017-10-16 22:47
The best way to transfer the video is to remove the sd card from the drone and insert it into the pc.    If you want to do it with the usb cable, make sure you are using the usb port on the camera, not the one under the rubber flap on the drone body.
2017-10-16
DJI Diana
Flight distance : 2408 ft
Agree with Kneepuck, besides, there is no need to power on the RC and connect the RC to the APP when you are exporting the images and videos from the drone to a PC.
2017-10-17
Maurxzy79
DJI Diana Posted at 2017-10-17 01:08
Did you test? Ok I know that is not necessary power ON the RC, but I want to be sure that is normal NO SIGNAL or it is a real error message.
2017-10-17
DJI Susan
Maurxzy79 Posted at 2017-10-17 01:33
The drone was not designated in that way. Disconnect the PC and restart the unit is helpful to verify whether the drone works well.
2017-10-17
Maurxzy79
DJI Susan Posted at 2017-10-17 04:12
ok thank you very much for assistance
2017-10-17
Spacer2711
Flight distance : 627979 ft
Just a little thing. There are USB cables for charging and USB cables for data transfer. Both look the same. Use the correct cable.
2017-10-17
DJI Susan
Maurxzy79 Posted at 2017-10-17 04:46
You are welcome! Feel free to contact us if you have more questions.
2017-10-18
