Expedia
Flight distance : 149613 ft
At least if you are using an actual iOS device you should be fine soon because the vulnerability is fixed in the actual iOS (public) beta which will be released soon. On Android you can only hope that you will see an update for your device depending on your model/carrier etc. or that dji brings up a fix on their side.
From what i can see it should be safe if one device (client or AP) is patched, seeing both sides patched would be your best option but a patched phone/tablet should do the job. |
