Gimbal Calibration Stuck on 50%
932966 932966 2017-10-17
DJI Thor
Flight distance : 13602 ft
Alvaro L Posted at 2018-5-16 12:54
Hi, I have this very same issue in a week old Phantom 4 Advanced +, won't finish gimbal calibration and gets stuck at 50%, all the other parameters and calibrations seem to work just fine. Can you add me to the beta testers list please Susan? My account mail is
alvarolunab@gmail.com
Hi Alvaro, I had replied your post, please check.
2018-5-16
DJI Thor
SledgeHammer Posted at 2018-5-16 13:18
Niiiice.. An official P4P fix and only beta BS for P4A. DJI Go better not force me to update to this faulty new firmware.
The firmware for Phantom 4 Adv has not officially announced. If there is a need, users can provide us with their DJI accounts to have the beta firmware.
Sorry for the inconvenience, hopefully, the firmware for Phantom 4 Adv will be officially published soon. Thank you for understanding.
2018-5-16
DJI Thor
amell Posted at 2018-5-16 14:42
Much better now I have upgraded!. Liking the new pano modes, spherical, 180 and horiz/vertical. Fixed the gimbal calibration issue and the other loss of signal issue I was having on the other thread. Plan to fly it a few times later this week
Thank you for your update. Should you have any further questions after the flight tests, please feel free to contact us at any time, we will do our best to help.
2018-5-16
adamski7900
i got the same with my dji  p4 advenced plus , any one can help ?  account --   adamski79@interia.pl
2018-5-17
Alvaro L
Flight distance : 8832 ft
DJI Thor Posted at 2018-5-16 20:12
Hi DJI Thor
The beta released works and now gimbal calibration is able to finish. Thank you very much. I would like to ask you about the camera not pointing straigh, with a slight deviation to the left. The gimbal calibration did not solve this issue.
By looking at other sources of information, it seems to be a common issue, but I really dont want to send the drone to the repair shop, I just want to fly it since it is not a big deal to me. Anyway, I would like to ask you for a feature request which is that the same way the camera roll axis can be manually adjusted, if in future DJI GO releases the camera yaw axis can be manually adjusted as well, maybe is not that complicated. I will file this also as a feature request in the DJI GO app. Anyway I am interested in your opinion about this issue. Thanks in advance.
2018-5-17
Aardvark
Flight distance : 384432 ft
Alvaro L Posted at 2018-5-17 04:17
Hi DJI Thor
If you look in the gimbal settings menu in DJI Go 4, and look at 'Adjust Gimbal' you should see options to adjust the Roll & Yaw of the gimbal manually. These values are then saved by aircraft.
Edit:- see this post https://forum.dji.com/forum.php? ... p;page=1#pid1129656
2018-5-17
Alvaro L
ah thank you so much
2018-5-17
DJI Thor
adamski7900 Posted at 2018-5-17 03:43
Beta sent, please check.
2018-5-17
DJI Thor
Thanks to Aardvark reply, for Phantom 4 Adv, gimbal yaw is adjustable. Please check if it helps to correct your situation.
2018-5-17
Alvaro L
DJI Thor Posted at 2018-5-17 22:34
Yes it helped, now it is pointing right ahead. Thanks
2018-5-18
DJI Susan
Sorry for the late response. I've received your message and will add you in later.
2018-5-21
DJI Susan
Thanks for keeping us updated. Feel free to contact us if there is any question.
2018-5-21
dfman_montana
Flight distance : 55125 ft
Another victim of the gimbal calibration problem and all my videos currently have a slight shake to them. Sent PMs to request the beta version.
2018-6-1
DJI Susan
dfman_montana Posted at 2018-6-1 09:55
Sorry for the late response. I'll forward to the right team to add you in.
BTW, it is suggested to click the reply button message if you need one's attention so that he/she can receive the notification and handle it timely.
2018-6-11
SafetyGuy71
Susan, will you please send the fix.
mtaylor742@gmail.com
2018-6-19
mackthekn1fe
Flight distance : 154324 ft
Estonia
Hello Susan!
Would you please send me the fix as well.
artyom.dougan@gmail.com
2018-6-20
mackthekn1fe
Estonia
DJI Susan Posted at 2018-6-11 03:07
Hello Susan.Would you please send me the fix as well. Thank you!
2018-6-20
DroneBees
Flight distance : 6698159 ft
I have the same problem.. P4P
fixed by rolling back firmware... calibrating.. then updating firmware.  It now completes the calibration but the camera does not move during the process.  I'm not sure if that's how it's supposed to work.  With previous firmware the camera would move during calibration.
2018-6-22
DroneBees
So is DJI ignoring us now?
This is an iOS bug.  It happens when I switch modes using my iPad and it also makes the HDMI output module break.
If I use an android phone/tablet to switch video modes it fixes the problem until I try to use Apple again.  How does one get in touch with support?  Email has been 48hrs with no response.  This thread is obviously not being read.
HELLO? DJI?
2018-6-27
DJI Susan
SafetyGuy71 Posted at 2018-6-19 12:32
Received with thanks! I'll forward to the right team and add you in.
2018-6-27
DJI Susan
mackthekn1fe Posted at 2018-6-20 07:34
The beta is estimated to be ready around 1-2 working days, please check and try later.
2018-6-27
DJI Susan
DroneBees Posted at 2018-6-27 06:45
Sorry for the late response as I just read this post. I've forward this to the designated team and add you to the list.
Also, it is recommended to check the reply button under one's message, so that we can get the notification and handle it timely, thanks!
2018-6-27
Ruilof
Flight distance : 75666 ft
Same problem here. Calibration gimbal stops at 50%. After refreshing all the firmware and factory settings of both the drone and the RC I calibrated the IMU first. After that the calibration of the gimbal was successful!
2018-7-4
DJI Susan
Ruilof Posted at 2018-7-4 05:00
Just to verify, it is a P4P, right? If yes, the gimbal calibration issue has been fixed in the official firmware, no worries. Should there is any further question, feel free to contact us.
2018-7-6
MOTOTOGO
DJI Susan Posted at 2018-7-6 00:03
I have a new P4A and neither the gimbal nor the IMU successfully calibrates even though I have apparently the current firmware on both RC and unit.  Camera won't point straight ahead / horizontal, won't keep level horizon when panning or moving (not in FPV mode).  About to return it to B&H as I'm thinking this one is a lemon.  Pls upload beta if this is still in effect to jennifercox@mac.com . Thanks
2018-7-6
DJI Susan
MOTOTOGO Posted at 2018-7-6 18:01
I have a new P4A and neither the gimbal nor the IMU successfully calibrates even though I have apparently the current firmware on both RC and unit.  Camera won't point straight ahead / horizontal, won't keep level horizon when panning or moving (not in FPV mode).  About to return it to B&H as I'm thinking this one is a lemon.  Pls upload beta if this is still in effect to  . Thanks
Received with thanks! I'll forward to the right team and add you in. It the issue persists after refreshing the firmware, please kindly upload some sample videos for further assistance, thanks!
2018-7-7
MOTOTOGO
DJI Susan Posted at 2018-7-7 00:58
Hi Susan - no luck and not able to fly without successful IMU calibration. The camera seems to want to be pointed about 30 degrees and slightly tilted.  When I did fly it before, it lost horizon with the slightest pan movement....
2018-7-7
DJI Susan
MOTOTOGO Posted at 2018-7-7 11:26
After you got the beta, please make sure the firmware update is successful, then do IMU calibration and gimbal calibration to see whether it works.
2018-7-9
MOTOTOGO
DJI Susan Posted at 2018-7-9 01:09
I didn't get the beta  - or maybe I just don't see where it's loaded for me to update...
2018-7-10
DJI Susan
MOTOTOGO Posted at 2018-7-10 15:29
Sorry for the late response. I'll double check with the right team, you may try to refresh within one working day.
2018-7-13
MOTOTOGO
DJI Susan Posted at 2018-7-13 03:39
Hi Susan,
I just PM'D you hoping to catch you on a Friday.  Still no luck.  Updated with the Beta, recalibrated IMU and Gimbal (which did complete) but same problem.  Please advise asap.  Thank you.
2018-7-13
DJI Susan
MOTOTOGO Posted at 2018-7-13 15:20
Hi Susan,
Could you upload a short video of the gimbal issue? We'd like to check the exact status and see whether it can be figured out remotely.
2018-7-16
Kraven90
Indonesia
DJI Susan Posted at 2018-7-16 02:43
hi susan,
My AC Phantom 4 Advanced
1. When starting the aircraft, the camera makes a moves as the ghimbal is warming up. The camera gets its horizontal-front possition  but after a few seconds  a noise comes out from ghimbal and it lose its position making a tilt down.The camera aim (tilt) down  a little bite (approximate 70degrees ) when it is suppossed to stay firm at 90degree (horizontaly)
2. When I fly the aircraft and I comand rotating to the left or right the camera has a tilt up and then slowly moves to the horizontal position.
3. I have tried again to auto calibrate the ghimbal but it gets stuck at 50% calibration process.
4. Brand new out of the Box, havent been fly before
5. AC Version 0128
I really need help, please!
2018-7-20
Kraven90
Indonesia
DJI Thor Posted at 2018-5-17 22:31
hi DJI Thor
5. AC Version 0128
2018-7-20
Jake12
Flight distance : 376617 ft
Sweden
Kraven90 Posted at 2018-7-20 21:00
hi DJI Thor
You need the 0800 beta version!
2018-7-20
Kraven90
Indonesia
Jake12 Posted at 2018-7-20 21:49
do you have the download link? is it really fixed the problem?
2018-7-20
DJI Thor
hi DJI Thor
Hi Kraven, I suggest that you try the beta firmware. Please leave me your DJI account, I will help to forward the beta. Thanks.
2018-7-21
Kraven90
Indonesia
DJI Thor Posted at 2018-7-21 03:53
Hi DJI thor,
My dji account : yohansenj@gmail.com
2018-7-21
Kraven90
Indonesia
the Beta version will be available in DJI Assistant 2?
2018-7-21
DJI Thor
Kraven90 Posted at 2018-7-21 04:38
Sorry for the delay. I had forwarded the beta to your account, please check. You can update it via the DJI Assistant 2. Please let me know if you haven't received it, thanks.
2018-7-22
