Alex G
Flight distance : 1366857 ft
Dear Susan
The problem that you are talking about, is caused because the motor that controls the horizontal movement has a vibration. this vibration causes the self-calibration of the gimbal to stop at 50%. if you reinstall the firmware, it seems to be fixed, but when the equipment is cooled, and you turn on the drone again, this problem appears again. This problem I do not know if it is firmware or hardware, in some units of phantom 4 Pro / Adv According to my tests, this problem currently affects all the firmwares. This vibration appears randomly, and it is the second unit that I sent to RMA for this reason. I would like to know if DJI is going to solve this, to know if I should send my unit back to repair. These vibrations can cause jello effect in the image in certain occasions. I do not know if DJI uses different manufacturers of gimbal for phantom 4 Pro / advance series, because if it were a problem of firmware it would be present in all the units of the market. I would like to know if DJI knows this problem and know the opinion of the engineering team.
My DJI account: esferadrone@gmail.com
My Phantom model: DJI Phantom 4 Pro Obsidian |
