Paul Tomo
Flight distance : 607336 ft
I took the P3P for a fly today and on the third battery change that I put the faulty battery in the drone. The faulty battery is already synced to the drone and rc and it recognises this faulty battery straight away, I hovered the P3P to about 2 to 3 Mts high, I also flew around but no more than 10 Mts away and stayed low to the ground. I looked on the battery page that 1 and 3 cells was lower in voltage than 2 and 4 by just under 1 volt and both 1 and 3 cell was in amber colour, both 2 and 4 green.
All 4 cells depleted at the same time and at the same rate neither any of the cells depleted faster than any other. When I landed the drone all the cells turned to green and when I took off both 1 and 3 turned to amber. The temp of the battery didn't stayed at a safe level and didn't heat up.
Iv'e now got the drone on the kitchen table with the faulty battery in and switched on until the battery runs out, then I'll put the battery on charge and see what happens. |
