lights for the spark
6700 22 2017-10-18
Gamorrean
so I would to get led lights for the spark or something to that effect for a little bit of night flying. I was wondering if anyone had put any on their spark or have modded any of the legs that you can buy for them? any help with this would be great. thanks for reading the post.
2017-10-18
lannes
Flight distance : 4465 ft
Strobe On , white cree  for the most visibility and velcro them on, so small and light they have not affect on the flying
http://www.flytron.com/led-syste ... ree-standalone.html
2017-10-18
Sparky_17
Flight distance : 62349 ft
These aren't very nice looking but they must work well based on the description.  Anyone use them before? please provide your feedback.  Thanks
2017-10-18
medyq69
Flight distance : 15358 ft
Poland
i wonder if u can use OTG from back from microusb to usb and use standard usb led lamp like this bulb? https://aliexpress.com/item/Elec ... st/32815984808.html
There are light also to legs mods - i seen video that its used at night - each need 1 x AA battery so its quite heavy finally - in forum here someone wrote that front of spark is then lower than back. In YT video its look fine but dont know how well it works
2017-10-18
Montfrooij
Flight distance : 2560453 ft
I wonder why you would want that?
Is the Spark not lit enough by it's led lights?
(we can't fly at night in NL)
2017-10-18
DJI Elektra
I would not recommend you fly at night. Since there is no sufficient light, the performance of VPS will be bad. In addition, led light from the third party is not tested and it will affect the performance.
2017-10-18
doZer the ogre
Flight distance : 78563 ft
DJI Elektra Posted at 2017-10-18 20:17
I would not recommend you fly at night. Since there is no sufficient light, GPS signal will be bad. In addition, led light from the third party is not tested and it will affect the performance.
yeah seems like a dodgy idea... Just wondering why would the GPS be lacking at night and not during the day?
2017-10-18
Wachtberger
Flight distance : 261509 ft
doZer the ogre Posted at 2017-10-18 20:30
I assume VPS was meant.
2017-10-18
Anuvis
Flight distance : 1976736 ft
Greece
why gps signal is bad at night?
2017-10-18
ASEPK
Flight distance : 35515 ft
Indonesia
Hi Elektra, sometime aerial photo for city is wonderfull for the night, would you give the tips for night flight?
2017-10-19
Viking-Pilot
Flight distance : 2379249 ft
Anuvis Posted at 2017-10-18 23:35
I think she meant the VPS, not GPS...just a thought
2017-10-19
Anuvis
Greece
Viking-Pilot Posted at 2017-10-19 01:07
ah ok...........
2017-10-19
doZer the ogre
yeah seems like she edited it. makes lots of sense. VPS is crucial for RTH...  a feature i have yet to experience.
2017-10-19
Hankmeister
Flight distance : 19465 ft
medyq69 Posted at 2017-10-18 05:51
i wonder if u can use OTG from back from microusb to usb and use standard usb led lamp like this bulb? https://aliexpress.com/item/Elecshion-LED-Usb-Lava-Table-Lamp-Power-Bank-Book-Night-Light-Novelty-Bulb-Finger-Touch-Adjust/32815984808.html
There are light also to legs mods - i seen video that its used at night - each need 1 x AA battery so its quite heavy finally - in forum here someone wrote that front of spark is then lower than back. In YT video its look fine but dont know how well it works https://www.youtube.com/watch?v=NLf7LWxxOjs
thanks for the video.
I was surprised to see Spark flying with the lamps
I bought the same pkg, ie legs and lamps. I had no success in even taking off from the ground, cause Spark just tips forward into the ground. I returned the pkg. Did you launch from the ground when flying with the lamps.
I am wondering if having the stick sensitivity slider close to minimum could have added to my failure the launch?
2017-10-19
medyq69
Poland
Hankmeister Posted at 2017-10-19 22:54
Firstly - i dont fly with that that lamps - its not mine video. I just showed that they can by bought. I tested other led lamp powered from back usb port only on forum
2017-10-20
lannes
Sparky_17 Posted at 2017-10-18 05:02
I use them on all my drones for identification when flying , the also give you a visual indicator which way the drone is facing, if you loose the DJI Go4 app.
They are no use as lighting for the camera
2017-10-20
Lucas775
Flight distance : 50642090 ft
Please fly with caution at night.
2017-10-20
Javey
Flight distance : 503458 ft
I’ve done a bit of night flying, the lights on the drone seem more than sufficient for LOS flying.
2017-10-20
Range30
Flight distance : 11281079 ft
Yeah, flytron is a good place to purchase LED lights for drones. Just ordered a few yesterday for both my Mavic and Spark.
2017-10-20
Ryan's Sparky
Flight distance : 302316 ft
Norway
I have these legs (without the lights) they offer good clearance and help keep the gamble from overload grass
2017-10-29
steyn524
Pakistan
I would not suggest you fly around evening time. Since there is no adequate light, and I think this is best lamp.) the execution of VPS will be awful.
2019-1-25
Lysak2003
Flight distance : 500052 ft
Ukraine
Voice and an accent of the reviewer are just perfect. I am ready to sit there and listen him for ages.
2019-1-26
jhon341
I'm looking to get some LED lights for my Spark drone, or maybe something similar, to make night flying a bit more exciting. I was wondering if anyone has tried adding LED lights to their Spark or customized any of the available leg options. If you have any tips or suggestions on this, I would really appreciate your help. Thanks for taking the time to read my post! Oh, and by the way, if you have any insights on creating a bespoke lamp, that would be awesome too!
https://thelampfactorylondon.co.uk/radiance-collection/
2023-7-11
