Matioupi
Flight distance : 922569 ft
Bright Spark Posted at 2017-10-20 08:14
So when CS won't connect to remote in 5.8, which is blocking?We deduce CS must use other than 149-161 when connecting to home router, so remote must only want to use 149-161.
exactly, remotes (Spark, Mavic, P4P) can only use 149 to 161, this is the 5,725 - 5,825 GHz range that you will find in DJI Specs (other 5.8GHz channels are below 5.725)
check table at the end of
https://en.wikipedia.org/wiki/List_of_WLAN_channels
This is a very small subset of 5.8Ghz Wifi channels and most android devices are having trouble with it, if they use a EU regdomain.
What is strange is why a CS in europe without SIM card, GPS position or "view" of many broadcasted country code (by neighbouring wifi) would use a european country code that pervent this band when the remote is broadcasting "US" that should result in allowing those channels (the regulatroy database is correct for those channels under US code)
That's why I was suggesting to remove all recorded wifi networks, turn GPS off, turn CS off, turn RC on, and then CS on again and then pair its Wifi. (if possible without other wifi networks in neighborhood)
I was hopping that this way, the CS would stick to the US regdomain of the RC and allow 5.8GHz.
(upon start, Wifi regdomain is usually set to 00 = world code that temporarily allows all channels to allow pairing).
By some mechanism that i can not understand yet, the CS must already be in a regdomain that prevent 5.8GHz SRD channels. |
