Pappy3
Flight distance : 2820469 ft
Dimu may have the same problem as I about having the WiFi and cellular connection on at the same time, I believe the phone's hardware just simply doesn't support this. I have a Moto G5 Plus and have tried turning on "Cellular data always active" under the "Developeer Options" settings and as soon as I connect to the Spark RC via WiFi the cellular connection is disconnected and so no internet connectiveity while connected to the Spark's RC.
Dimu, you have two options to have a map while flying- Preload the map - open the DJI Go 4 app, click on the hamburger like icon (3 horizontol lines) in top right corner of app, select "Offline Map", then select the appropriate region/state. (As of this writing the "Offline Maps" isn't working for Ver 4.1.10. I get the message "Acquiring Offline City List", which fails, and then I can no longer manage offline maps.)
- Use an OTG cable to connect your phone to the RC. Since you no longer need WiFi to connect to the RC your cellular connection can remain on. Maps can then be downloaded over the internet while flying, including satellite overlay.
