zazaki
Switzerland
DJI Thor Posted at 2017-11-30 19:17
Hi Zazaki, I would like to know more info about your case, coz you mentioned you are not able to film in 4K. When you said this, is it that when you select 4K, the SD card gives you the message "SD card invalid" or I misunderstood you.
Please try to do a camera reset, or format the SD card on the PC and try again.
Besides, we suggest using SD card with Class 10/UHS-1 and above and writing speed with 60Mbps. Please kindly choose original SD card from the SD card company, which can ensure the full test of its stability and compatibility.
When I try to film in 4k, what basically happens is as follow. I touch the record button on the DJI app ; the button becomes square ; the timecode stay indefinitely at 00:00:00 ; when I try to press the red square button, nothing happens ; it stays as a red square button. Then when I quit the app and relaunch it, it say "SD-card invalid".
I TRIED TO RE-FORMAT ON THE APP ("FORMAT FAILED", RIGHT AFTER THE BUG DESCRIBED BEFORE)
I TRIED TO FORMAT ON PC (FOLLOWING DIFFERENT METHOD) ; MAC
MY SD CARD PROVIDER IN SWITZERLAND IS A SERIOUS ONE
I TRIED EVERYTHING. ONLY AN "OLD" KINGSTON CLASS4 IS ABLE TO SHOOT IN 4K
I TOO HAVE SMALL NUMEROUS DISCONNECTION WHEN FLYING LIKE 250 METER
I have re-start entirely the drone each time i want to fly, because I always got the flight limitation working in background (even when not active)
https://drive.google.com/file/d/ ... Hx/view?usp=sharing
