Phantom 3 Pro prop issue
2223 12 2017-10-18
fansa059245f
Flight distance : 1880 ft
Have an issue with just one prop not wanting to spin is there easy way to replace? Are the physical locations that will work on these or do i have to mail it in to dji?No crashes or anything with it, had a hard time getting to update the firmware about a year ago and since then prop stoppped working I ended up getting a new drone but would like to get this one fixed any ideas?
Thanks
Adam
2017-10-18
DJI Susan
Adam, is there any error message in APP? Please try to replace the propeller and mount it properly to see whether it helps.
2017-10-18
adpal
DJI Susan Posted at 2017-10-18 18:30
So just changed the prop and went to turn it on now it shows and error message about firmware to remote so i will try updating remote now
2017-10-19
adpal
ok so i now have the remote updated to what i believe is the newest version v01.11.0020  When start up the drone and app now it shows the view of the camera for a few secounds then just looses connection and the picture goes away  Before goes away i am seeing error that battery requires update and camera requires update not sure what that means
2017-10-19
adpal
adpal Posted at 2017-10-19 05:39
I'm now getting error message that battery and camera require update
2017-10-19
DJI-Jamie
Flight distance : 112405 ft
Please keep us posted on how everything went.
2017-10-19
adpal
DJI-Jamie Posted at 2017-10-19 13:54
So i now have the controller updated i think part of the issue is some of my batteries need to be updated but i found one that seems to work and will connect and the app will function.  Still having issue with the same prop the won't spin. (i have installed new prop on that one)  Do i need a new motor?
2017-10-19
adpal
adpal Posted at 2017-10-19 14:03
Its telling me to follow a link that my current controller doesn't support Go Firmware Update and download firmware at dji product support inspire-1 download   v1.3.20   link doesn't work and can't find this download on site to try
2017-10-19
DJI Thor
Flight distance : 13602 ft
adpal Posted at 2017-10-19 14:16
Please go the website below and update the drone's firmware to the latest version. If the motor keeps the same issue, please send it back to us, we will help to take care of it. http://www.dji.com/phantom-3-pro/info#downloads
Below is the tutorial:
2017-10-19
adpal
DJI Thor Posted at 2017-10-19 17:52
Below is the tutorial: https://www.youtube.com/watch?v=EPuhdZ4l18Q&list=PL8-vxWY64sBMWJEBFEM6Jc_nLk0zfyPtS&index=9
followed the link are downloaded firmware it updated the drone correctly checked the results after and said it worked.  Now it doesn't connect with controller.  I tried using same firmware on controller and it said that its the same as current firmware.  Light on controller is flashing green to red real fast not sure what that means   Thanks
2017-10-22
DJI Diana
Flight distance : 2408 ft
adpal Posted at 2017-10-22 17:17
Try to reset the remote controller.
* Turn on the controller, and make sure the aircraft is off.
* Press C1, C2, and shutter on the controller and then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
If that does not work try to force the controller to update:
* Turn on the controller, and make the aircraft is off.
* Press C1, C2, record and the wheel on the right side of the controller and then turn off the controller.
* Don’t let go of any of the buttons, turn on the controller. Then the controller will be able to update again.
2017-10-22
adpal
DJI Diana Posted at 2017-10-22 20:11
Tried out the reset as well as forcing the update still not connecting to the drone it connect for just a second picture was super pixelated and only showed like half of the screen.  Was showing the error again that controller doesn't support version DJI app and to update controller.  Then it disconnects from drone after maybe a minute
2017-10-23
DJI Diana
adpal Posted at 2017-10-23 19:04
Could you please provide a short video or some screenshots about it? Besides, what is the current firmware version of the RC?
2017-10-23
