fansa326285e
Flight distance : 337608 ft
Norway
Hi folks.
My PC run Windows 10. Right now, actualy this are first time to use firmware Assistant2 for upgrade. During Win-7, no problem at alll in use.
Now in Windows 10, the area for given verification code are clear, empty. It is possiblee t change "some things" by a hand occur in this field by moving mouse to this area.
Think this are 6 time for install/remove. At first time installation my Bitdefender Total Sequrity 2018 block some part of this process by install Assistat2. So this restricted area for write controlled by Birdefender are removed from option in Bitefender. This error message: IpersistFile :: Save Failed; code 0x80070005 No access, did no longer occur.
I can see a txt log file are produced after installation. Try hard to locate this file, no found, so far.
Any tip for non see any code information in verify field?
Thank you, I knew I couldtrus on you for support me.
