DroneFlying
Flight distance : 10774613 ft
This seems to most commonly caused by the Mavic thinking it's still close to the ground, which in turn is a result of the bottom sensor detecting something nearby such as landing gear extensions or part of a tracking device. If you have anything like that attached to your Mavic then try flying without the accessory and also make sure there's no dirt or other debris blocking the bottom sensors.
If all that fails then retrieve the DAT file from the flight, upload it to DropBox, and provide a link here and I'll take a look. The instructions for accessing the file are here and the correct file will be tens or hundreds of megabytes in size and have a timestamp that corresponds to when the flight occurred. If you aren't able to locate the appropriate DAT file (it should be an "FC" entry in the list) on your first attempt then try powering the aircraft off and on a few times and hopefully it will eventually show up. |
