Request: presets for stiffness
1093 3 2015-4-8
emiliandechev
Bulgaria
Hell DJI !
I recently purchased your gimbal - the Ronin. Really nice peace of hardware. But I encountered a very annoying problem. When changing different camera setups, the "auto calibrate" function does a mess with the motor stiffness values. I better set them manually. But I need different numbers for different camera setups. Can you add a preset function for the stiffness numbers? Thanks.
2015-4-8
DJI-Cathy
We do not have any recommend stiffness for different camera, and the stiffness numbers depends on you, you'd better manually set the value to see which one is best for you
2015-4-10
emiliandechev
Bulgaria
Yes that is the case, but you did not understand my request. I want to set the values manually and remember them as a preset. So next time the values reset to default, I could have 1 click loading my preset. Is that possible to be included in the software?
2015-4-15
DJI-Cathy
currently I am afraid not, but it is a good idea, we will consider it
2015-4-24
