Nigel_
Flight distance : 388642 ft
A GoPro mounted solidly on top of a Phantom seems sensible, you can use the wifi to see what you are doing and take photos unless your ceilings are really high. It will need a solid mount or there will be too much vibration. The Phantom is a good choice of drone due to the visual hold, much easier to fly indoors than most, if there is a decent amount of light.
Also put some sort of tall spike on top so that the props can't get too close to the ceilings, the airflow into the props will get uncontrollable as the props get close!
Might be better to use one of the 90 degree action cameras so that you don't have to get so close, eg a Gitup Git2P90.
