I take it you've downloaded all the onboard SDK source files? It may be possible to tap into the canbus of the A3 and read the event that you designate toward your task; however, you'd need a frontend on the Jetson to listen for this event and trigger your program accordingly.
On the otherhand, you could make converter fairly easy with something like a Teensy, Arduino, or similar with something like this for code: (Or use actual C++ if you're a programmer).
- #define PWM_Pin, 2
- #define JetsonPin, 3
- void_loop()
- pwm_value = pulseIN(PWM_PIN, HIGH, 20000);
- if (pwm_value > 1500)
- digitalWrite(JetsonPin, HIGH);
- else
- digitalWrite(JetsonPin, LOW);
You might be able to get away with a RC FlySoft Switch and attach one lead to your Jetson GPIO VCC and the other to your listening pin. Basically does the same thing as above.
Cheers
