Still no 4096 x 2160 recording mode!
1603 23 2017-10-20
fans75d005bc
Flight distance : 797 ft
Hi there
My appologies for having to repost this issue but DJI have just left my earlier post unsolved. DJI state that I can change the ratio to 17:9 to get this recording mode. The point is that there is no option for this in the latest firmware of software. Please DJI can you assist me with this!
2017-10-20
DJI Elektra
Can you provide the screenshot of your app when you are in the 17:9 ratio? Thanks for your support.
2017-10-20
fans75d005bc
DJI Elektra Posted at 2017-10-20 02:25
There is no option anywhere for the 17:9 ratio
2017-10-20
fans75d005bc
Here is the screenshot again - there is no option for 17:9 size - you have removed this from the firmware which is what I am complaining about
2017-10-20
DJI Elektra
fans75d005bc Posted at 2017-10-20 03:53
Thanks for your update. It is abnormal that your drone doesn't have this option. I can find the 17:9 ratio in the app. I would forward this to our engineers for check. Please wait patiently.
2017-10-20
Sinamics
Flight distance : 837851 ft
South Africa
I had the same problem, could`t get the 4096x2160 option, nor the 17:9.
I opened my Litchi App and there i had the option to select 4096x2160 with various FPS..
Then i closed Litchi and opened Go4, and guess what...    i now have the 4096x2160 option in Go4 app as well.
2017-10-22
DJI Elektra
Did you have SSD with your drone? Please try to install the SSD first and select the resolution in the "cinemaDNG" item. If not, please use Android system. Thanks for your support.
2017-10-22
DJI Elektra
Sinamics Posted at 2017-10-22 08:08
Sinamics, please follow the advice in 7# and keep us updated. Thanks.
2017-10-22
fans75d005bc
DJI Elektra Posted at 2017-10-22 18:15
Thanks for the help. However just a couple of points. Yes if you open the Litchie App first and then the DJI Go 4 App you can see the 4096 recording mode. However as soon as you change any settings or close the app again it disappears.  May be a temporary solution but DJI need to address the bug.
Also I am not sure why I am being asked by DJI if I have the SSD installed. I do not have an SSD and neither of the licences. My point is that I should not required this according to the manual.
Thanks - please can you keep me updated.
Also the Androd solution is not an option. I only own Ipads and iPhones. These should be supported as a priority
2017-10-23
DJI Elektra
fans75d005bc Posted at 2017-10-23 00:34
Sorry for the trouble it brings. Our engineers will fix this in the next version.
2017-10-23
DJI iOS Team
DJI R&D Squad
Hi, SSD and SD recording ratio is same. If u want to set 17:9, set  SSD resolution first.   If u donot want SSD, set SSD off or set SSD resolution NOTRECORD, then u will find all the ratio and resolution at SD resolution pulldown box
2017-10-24
DJI iOS Team
DJI R&D Squad
Err, I shall check it
2017-10-24
DJI iOS Team
DJI R&D Squad
Hi, SSD and SD recording ratio is same. If u want to set 17:9, set  SSD resolution first.   If u donot want SSD, set SSD off or set SSD resolution NOTRECORD, then u will find all the ratio and resolution at SD resolution pulldown box.
If u do not hv a SSD card, plz wait still DJIGO 4.1.14 to fix "SSD resolution cannot change with SSD card unpluged" or use a old version DJIGO to set SSD off...
2017-10-24
fans75d005bc, the post in 13# is from our R&D engineers, please refer to it and we are sorry for the inconvenience and confusion caused.
2017-10-27
Altitude Drones
Flight distance : 1488520 ft
2017-10-27
Well, I just saw a smiling face, please post again if you need any assistance.
2017-10-28
fans75d005bc
DJI Elektra Posted at 2017-10-23 02:18
Can you please advise when this is going to be addressed!!
2017-11-1
fans75d005bc Posted at 2017-11-1 03:04
APP iOS v4.1.15 has been released, would you please update to have a try?
2017-11-2
CFIREGUY02
Flight distance : 1909606 ft
I just asked the same question and I just figured it out.  Go onto the Cinema Dng side and click just below where it has CDNG/422HQ/4444XQ and click on the 16:9 it will show 17.9 4096x2160 click on that.  It will say you don't have the key but it will move over onto the H.264/H.265 side.  I'm going to to post a YouTube link I just made for this.
2017-11-2
CFIREGUY02
Here is the video answer you are looking for
2017-11-2
CFIREGUY02 Posted at 2017-11-2 17:48
Here is the video answer you are looking for https://www.youtube.com/watch?v=id4tOWwg7_Y
Thanks for the post, may I know what the APP version is?
2017-11-2
fans75d005bc
Great I will give this a try
2017-11-6
fans75d005bc
fans75d005bc Posted at 2017-11-6 08:56
Hi there - I don't know if I am just not getting something or not but I cannot update my DJI GO 4 App. It is showing version v4.1.12 but wont update to later version. What do I need to do??
2017-11-7
fans75d005bc Posted at 2017-11-7 23:37
What is the model of your mobile device?
For Apple device, pleas update in APP Store.
2017-11-9
