AlexVideoShark
Flight distance : 4535200 ft
Azerbaijan
Irate Retro Posted at 2017-10-21 00:18
Sure, the button is under the main "MC Settings" and it looks like this (proper screenshots below): [/img]
Take off from your height-obstructed location, such as under a canopy/awning or from inside your bunker or whatever. Fly to an open location making sure the aircraft has an open/safe path to ground at all times, so don't fly over your swimming pool or herd of llamas on the way to your desired new home point. There's no danger of a signal loss RTH causing an ascent and canopy collision within the 20m 'descend-only' radius, but after that you need to be out from under the canopy. Hover the aircraft at your desired new home point, even 400' up if you want.
yes , your explanation, look like very good ...
I've used this , but setting my RC position
on the screen map you can see your actually position of your RC
(but must be use a tablet/device with active gps,)
is my personal opinion ... now a normal phone/iphone or Ipad with active GPS can be very accurate, becouse they can use normal GPS and plus ,GPRS line and WI-FI sistem , all together ...
but we have to pay attenction and have a double check on map screen before to confirm position for RTH as you have explained on screen shot image..
it's even true that when we use a device without active GPS the position reading could be 20 miles away ... so to be careful when we using this function ...
anyway ... I've used this and after double checks done , the RTH was update correctly time by time during the travel ...
the changes done was evident on the map screen and on line battery life,
that's way I was able to travel for 10km, following and filming a car along a road and at end of travel ,the drone landed in safe into last Home Point put on the DJI GO App...
yes of course ... with other application , like litchi , maybe should be more easy ...
but in any case, I spended more time for double checks everythigs and planning it than click a button ...
AlexVideoShark |
