Geebax
Spappy Posted at 2017-10-24 17:06
I understand your point of view, but this isn't the 1st time I have done this, even though it might not be the BEST procedure, but this is definitely the 1st time anything like this has happened. If you'll notice, I stated that I WAITED for all the errors to clear and the green "OK for takeoff" message. Whether or not this is proper protocol is beside the point. I was aware of magnetic interference the 1st time I attempted to launch the drone in my driveway and was too close to my Datsun pickup. That's why I waited until I got the green "OK for takeoff" message. If that truly was the cause of the crash, no one has yet to identify it, only saying that a propeller flew off after takeoff, which is preposterous.
There is a subtle difference in the procedure. If you started it up in the car, then moved it out of the car, placed it on the ground, then waited for the errors to clear, then that is not the correct procedure. But, to be fair, there is nothing in the manual to tell you this. The green 'Ready For Take-off' message is not a guarantee that all is well in every respect.
The problem is, when the aircraft is first switched on, it initialises the compass unit (in the presence of all that metal) and then move it out of the car while switched on, you will retain a bad compass initialisation.
The correct prcedure would have been to switch it off again, move it out of the car, place it on the ground in an area free from any metal influence, and switch it on again. Then it will initialise the compass correctly, free from any metal. Please note that initialisation is nothing to do with compass calibration.
