ACW
Flight distance : 13926112 ft
_pk Posted at 2017-10-21 04:31
This is a normal behavior. If a camera (any camera) is not horizontal then the perspective shows up. It is just a basic geometry. In your case the camera is pointed downward, hence the lines, that would be vertical with level camera, converge below the picture. If you point a camera upward (not possible with Spark, but can be easily done with any "normal" camera) the "vertical" lines will converge above the picture. It is more evident with wide-angle lenses (and the Spark's lens corresponds to 25mm on FF) than with tele-lenses, yet it will occur always. As said, it is just basic geometry. Being humans, we are used to perceive vertical lines as vertical. That is because we are not birds. We are used to look more or less straight ahead. A bird would probably say that the second version looks strange :-)
BTW, I could give you a precise mathematical proof and explanation, but it may be hard to digest :-)
Great explanation however, if you are flying in Tripod mode you can manually tilt the gimbal +30 degrees upwards on the Spark. It also tilts upwards automatically to take pano's. |
