Donnie *
Flight distance : 3636782 ft
fans8cefa55b Posted at 2017-10-29 10:54
Still nothing is happening. There’s no lg on the SD card and I am using the original SD card. Could it be that if the firmware is on 1.2.1.06 it can’t be updated to the latest firmware because you have to update to another firmware first before you can update to the latest?
WITH THE X3 CAMERA :
Can you currently control your AC via the RC ? Start the motors and what not ? If you can , can you also see the data going to the Go app from the AC ? altitude speed and settings in general ? Is everthing working except you get no live video to the Go app device ??
let m eknow
Also here is a link to view the hidden file , make sure you are foing it corectly and I would love to see it if you can get a data to load . If it will not load and you follow all my spidey tips then I think I may know the problem . Let me know
How to View Hidden Files: Tool to diagnose No signal and SD Issues
Have you tried to load version 1.3 to the X3 camera ? Jsut wondering if the camera never was updated to version 1.3 and is stuck at version 1.2.1.06 Here is the file you will want at the bottom of this link . Here is link to a 1.3 file , be sure you ONLY LOAD THE BIN FILE TO THE SD CARD . You will see 4 files open up , only 1 is the bin file. do it just like when you updated the AC to version 1.11 using the x5.
AAAYlO3f4asJxMdkUQD5lTepa
donnie
****If the bin file 1.3 is not the problem then more than likely you have a fialed "Video Encoder " module on the X3 camera and will need to be sent in. The only glimmer of hope i see is the camera (X3 ) is on very old Fw and may just need to be updated to version 1.3 and then from there to the latest FW and then you should be good to go . If the 1.3 Bin file will not load and you get no log then more than likely thats the problem . Cost is about 1 -300 dollars or you may wish to get one off e bay , seen some pretty good deals lately .
