Issues Pairing M210 & RTK Ground Station
6423 7 2017-10-24
fansfc374f9e
Flight distance : 2263737 ft
Hi
I have a M210 RTK and I am having some issues setting up and pairing the ground systems to the 210
Detailed information on this process is a little scare at the moment so this is where we are now.
Each unit activated (3 units) via Assistant 2
RTK (Sky) on the cendence
Installed, operational, green light on unit, switch set to combo.
Ground Station
RTK unit :powered up, green llight on before firing up 210
Datalink Pro 900: Green light once reomote is started, switch set to combo,
Power up ground station first, then remote, after boot up I have 3 green lights betweeen the units.
210
set switch to "pair"
after boot up, cannot take off until I shut down the RTK via the toggle switch.
On DJI app
Antenna 1 & Antenna 2 find satellites
Ground station no satellites
210 reports heading
210 does not report position.
Anybody have any similar issues, or see any steps I have missed with above.
2017-10-24
Skee
Sweden
DJI gave me a solution " push the switch on the datalink which connects to the RTK base station to UART and the one which connects to the remote controller switches to CAN." and this works now i have connection to the basestation.
2017-10-31
NewsFlight24
Flight distance : 452753 ft
anyone have any info from DJI on setting up with M210?
2017-11-13
HUAVS
Flight distance : 2388 ft
NewsFlight24 Posted at 2017-11-13 11:55
DJI just put this out today on Youtube
2017-11-14
Phalcon-23
Flight distance : 91178 ft
No luck for me, Aircraft coords still say n/a. Base Station reports ok though
2018-5-31
rfAndy
Flight distance : 396365 ft
Mine used to work. Now it doesn’t. Same issue. Base station coordinates are fine. Nothing from aircraft. All lights correct and firmware up to date.
2018-6-2
rfAndy
2018-6-2
TechV
Argentina
Our Ground Station receives ok satellites, all the data links are in solid green light and all the firmware are up to date. We have Orientation in the Crystal but not Positioning. Also appears a "RTK base station antenna error". We can fly in GPS mode only
2019-1-15
