Firmware v1.11.30 for ESC error??
Fede_rico_84
Hi Susan, I updated to  v1.11.20 my P3A, also my RC to latest firmware but I cannot fly it. I have the following message: ESC Status Error Turn off aircraft and restart, Contact DJI support if this continues. If the v1.11.30 solves this problem please send it to me.
Thanks
Federico
2018-7-1
LarBear360
Flight distance : 63537 ft
Anna DJI Posted at 2018-7-1 05:26
Tyć, i have solved it  now everythink is working
I own a refurbished P3Pro. The kit was shipped with version 1.9.60 and 1.8.0 for the remote. Should I update straight to 1.11.20 or was there something in between. And is 1.11.20 going to mess me up? Should I obtain 1.11.30?  Everything is running perfectly at this time. I truly do not wish to go through this if I don't have to.
2018-7-1
Faneur58
Flight distance : 13996 ft
I received the file, but I find that the update ends badly each time, it lasts less than 20 minutes and always ends with a red dot.
yet the first time the version was read, drone without error. 20 minutes later: ESC error
2018-7-1
fans7c7c1d56
Flight distance : 492841 ft
Can someone please PM me the update? I need to get back in the air. Thanks
2018-7-2
SkyNet Aerial
fans7c7c1d56 Posted at 2018-7-2 08:45
DJI Susan, I sent you a PM
2018-7-2
DJI Susan
Sorry for the late response. The bin file is for the aircraft only, the red RC indicator means that the aircraft and RC do not connect, all you need to do is linking RC. Should there is any further question, feel free to contact us.
2018-7-6
Fede_rico_84
2018-7-6
Faneur58
it is deplorable not to follow up. this state ESC annoys me.
my phantom is not going to turn out of summer because of it. zero DJI
2018-7-8
PatMecheE
Hi Susan, I am having the ESC Status Error after updating the remote controller, phantom 3 pro, and the DJI GO app. Would you please be able to send me a link to the 1.11.30 ESC fix please for the P3P?
2018-7-9
Fede_rico_84
Sorry but my Dji Phantom 3 adv still can not fly due to Esc error.
It's been ten days without an answer ...
When can you send me the new firmware ...
Thank you
Federico
2018-7-9
storman
Russia
Hi all
I have a problem with phantom 3 pro
Its crashed when I low flying. About 2-3 meters high. Very sharply turned sideways with ESC error and fall down
I uploaded this to youtube
Logs from phantomhelp
Logs from airdata
Firmware P3P_FW_V01.11.0020.bin
DJI GO last version (android)
What was it and how to fix it?
2018-7-10
Vincent D
Flight distance : 622841 ft
DJI Susan Posted at 2017-10-24 18:50
Which drone do you refer? P3A or P3P? I'll help you get the v.1.11.30 firmware and try again.
Hi Susan I'm getting ECS error on my P3A can you please push me Firmware v1.11.30
2018-7-10
Rexen
Experiencing  similar issues but none of the alternate fixes has had any real effect.
I crashed my P3Pro a month ago (fatal) and my friend let me borrow theirs (which hadn't been used in quite some time (1yr +).
Inserted my old SD card from my unit (with latest firmware v1.11.20) and booted up the unit.
Tried to install firmware but continued to fail.
Downloaded .BIN file again and attempted again, continual failure.
Deleted .BIN files and log then reinserted and booted up again, seemed to go OK.
Linked my old RC controller (with latest firmware) to the P3 and opened app.
Checked all versions (all up to date, v1.11.20 FW, 3.1.42 APP, 1.9.2 RC) but had ESC issue for a while (props off).
This was resolved and now no longer have ESC issue but still no image feed from the camera and continuing to see the ATTITUDE mode is on (even though switch is toggled to P.
Keeps flicking between OPT and P-Att modes on the app.
I can see all the settings, the auto ISO changes if I put my hand in front of the lens, I can fly, take photos etc but completely unable to view camera feed from the app.
I can see the files on the microSD card but cannot stream to my devices via the app.
Have tried using different devices (Samsung Galaxy Note 8, Samsung Galaxy Tab Active 2, Google Pixel XL, Google Nexus 7 (using DJI Pilot old version).
None of these with various different cables has had any success.
Once when I tried the Nexus it said all firmware was out of date but no longer says that.
No other device has said so, all say up to date.
No idea what to try other than the 1.11.30 FW version and see if that helps.
Have PM's DJI Susam so hopefully she can link me the files asap.
PS: Why is it that an apparently more common than previously though problem has it's 'fix' closed from public/consumer access when it has been 'solved' for ~10 months ?
Shouldn't this be generally accessible via the support section ?
2018-7-11
Sinon
Flight distance : 7182 ft
Hello, I have the same problem. Esc error after updat v1.11.20
Please help.
2018-7-11
PatMecheE
I am in serious need of this update to fly in the next day for a project. Any help would be greatly appreciated.
2018-7-11
Fede_rico_84
I need to fly ... when it will be possible to have the new firmware ...
2018-7-13
storman
Russia
I am use firmware from this link link
Copter flies normally
2018-7-13
Manullord
I Also Need the version v1.11.30for P3P
2018-7-13
Vincent D
Can you please push or provide me Firmware v1.11.30 for my P3A
2018-7-13
Fede_rico_84
storman Posted at 2018-7-13 07:04
Which is the version for phantom 3 advanced:
P3S_FW_V01.11.0030.bin
P3X_FW_V01.11.0030.bin
Thank you
2018-7-13
FPVOne
Flight distance : 41276 ft
Need fix for phantom 3 advanced .. after upgrade to 1.11.20 esc error occurs ..
2018-7-14
lumik
Flight distance : 302267 ft
DJI Susan Posted at 2017-12-25 19:01
I've received your message in PM as well, thanks! As I mentioned in 111#, the firmware only fix ESC error. If you encounter other issues, please start a new thread, we'd like to help.
Hi Susan, I am having problems with my P3P gimbal control & pic/video feed, the bird otherwise flys as normal just can't control the up/down gimbal nor do I have any pic/video feed any longer. I have taken the 2 ribbons off to clean & reinstall the firmware says it's the latest but still no control, would the 1.11.30 update fix?
thanks
2018-7-15
DJI Susan
SkyNet Aerial Posted at 2018-7-2 08:53
Sorry for the late response. I just checked the PM and found that I have replied you several days ago. Glad to see the issue has been figured out. Regarding the average life, we're sorry that we do not have this data for now. Generally, there will be an error message if something goes wrong, no worries.
2018-7-16
DJI Susan
Fede_rico_84 Posted at 2018-7-6 11:26
Sorry for the late response, I've received your message and responded as well, please check later.
2018-7-16
DJI Susan
Faneur58 Posted at 2018-7-8 21:52
Sorry about this. The V1.11.30 only fixes the ERSC error after updating to the latest firmware. If it doesn't fix your issue, I'm afraid that you may consider sending the unit in. You may start a case from here: https://www.dji.com/support
2018-7-16
DJI Susan
PatMecheE Posted at 2018-7-9 18:53
Sorry for the late response. I've sent you a message in PM, please kindly check later.
BTW, if you need one's attention, please kindly click the reply button under one's message, so that he/she will get the reminder and handle it timely.
2018-7-16
DJI Susan
storman Posted at 2018-7-10 09:13
Hi all
I'm so sorry to read the accident. Please kindly start a case and send the unit in from here: https://www.dji.com/support If the unit is still under warranty period, we'll offer you a proper solution according to the data analysis result.
2018-7-16
DJI Susan
Vincent D Posted at 2018-7-10 11:04
Vincent, I've sent you a message in PM, please kindly check whether it is the correct file, thanks!
2018-7-16
DJI Susan
Rexen Posted at 2018-7-11 00:19
Hi Rexen, we're sorry for the troubles. The V1.11.30 only fixes the ESC error after updating to the latest firmware, I'm afraid that it is not able to fix your issue, you may try to re-seat the pins on the side of the gimbal to see whether it helps.
2018-7-16
DJI Susan
Sinon Posted at 2018-7-11 06:53
Please help.
I've resent the link in PM, please kindly check whether it is the correct one.
2018-7-16
DJI Susan
Manullord Posted at 2018-7-13 10:44
Sorry about this, I've sent a message in PM, please kindly check later.
2018-7-16
DJI Susan
lumik Posted at 2018-7-15 15:40
thanks
As mentioned above, the V1.11.30 only fixes the ESC error after updating to the latest firmware, I'm afraid that it is not able to fix your issue. For your situation, I sincerely suggest to send the unit in for diagnosis: https://www.dji.com/support
2018-7-16
DJI Susan
FPVOne Posted at 2018-7-14 14:54
I've read your comments on another post, please kindly check whether you have received my message in PM, thanks!
2018-7-16
riggers
Flight distance : 2297 ft
Hi does anyone have a fix for the conrtoller issue causex by the last firmwafe upgrade im getting nothing from dji getting annoyed
2018-7-16
DJI Susan
riggers Posted at 2018-7-16 07:36
May I have more details of the RC update issue? What's the color of the RC indicator?
2018-7-18
fans3e9a0c17
I am getting an error with my Phantom 3 Professional.  ESC error.  I have rebooted the aircraft but it not allow me to take off.  I just PMed Susan and asked for a link to the file.
Personally, I think this kind of thing is crazy.  This is a known issue, so why not make the fix public?  Now I am stuck without being able to fly.
2018-7-18
Fede_rico_84
I updated my phantom 3 adv firmware 1.11.0030 that I was sent Dji Susan but I have not solved the problem ....
Esc error contine to persist ...
I also contacted the online support of dji without solving anything!
I wonder how such a widespread problem is not solved by an official update ...
it is more than a month that I can not use my phantom ...
2018-7-19
DJI Susan
fans3e9a0c17 Posted at 2018-7-18 14:55
Sorry for the troubles. I've received and responded your message in PM, please check later.
2018-7-19
DJI Susan
Fede_rico_84 Posted at 2018-7-19 01:49
Fede, I understand your frustration, for your situation, we sincerely suggest to send the unit in for diagnosis: https://repair.dji.com/repair/index The designated team will take care once the unit arrived. Appreciate your understanding.
2018-7-19
misterlama
bignasty Posted at 2017-10-25 13:55
It works! updated the firmware and the engines fired up first time. DM me for the link to the download page.
Totally desperate. Installed the  latest firmware . 1.11.20 and i stille receive esc status error. Tried downgrading No succes
2018-8-26
