Compass
1221 12 2017-10-25
Dgreene4242
Help for a new owner- I just bought a Phantom 4 Advanced, I see in the youtube Video's everybody say you should calibrate the Compass on each flight.  I see the field Compass Normal but i don't see "calibrate compass button" .  I have the most current firmware.  what am i missing?
thanks
DG
2017-10-25
ALABAMA
Flight distance : 10442687 ft
You should never calibrate before every flight.  I haven't calibrated in over a year.
2017-10-25
Marcelo Nannig
Flight distance : 383602 ft
Chile
It is not necessary to calibrate compass every time...unless DJI GO 4 app alert you to need calibration.
2017-10-25
Geebax
You are probably looking at an old video, back when everyone, including DJI, thought it was a good idea to calibrate before every flight.
But it is not a good idea, never was, and nowadays the advice is to only calibrate the compass when the Go App asks you to.
2017-10-25
Paul Tomo
Flight distance : 607336 ft
Even if your visiting a new location? you are saying don't calibrate unless dji do app prompts you to?
2017-10-25
Geebax
Paul Tomo Posted at 2017-10-25 14:49
To all extents and purposes, the 'new location' thing is a red herring. And no, don't calibrate unless the Go App asks you to.
2017-10-25
M.C. Pilot
Flight distance : 10278435 ft
"say you should calibrate the Compass on each flight. "
Don't believe the hype.
2017-10-25
Labroides
Flight distance : 9991457 ft
Go to p57 of the P4 Advanced manual and it tells you everything you need to know about calibrating the compass.
It doesn't say anything about calibrating when you fly from a new location, nothing about 100 miles or 1000 miles.
And nothing about calibrating the compass before flying for the first time.
Summary:  Don't mess with your compass.  Just leave it alone.
2017-10-25
DJI Thor
Flight distance : 13602 ft
Here are some scenarios that we suggest calibrating the compass:
1. When compass data is abnormal, and the Aircraft Status Indicator is blinking red and yellow.
2. When flying in a new location, or a location that is different from your last flight.
3. When the aircraft moves erratically during flight, i.e. the drone doesn't fly in straight lines.
You can go to this route: MC Settings--Advanced Settings--Sensor State--Compass--calibrate.
2017-10-26
DJI Elektra
Here are some situation that you need to calibrate your compass:
1. Bad flight performance
2. It is hard for your drone to hover stably.
3. Can not fly in a straight line.
4. A new flying place.
5. Reminder from your app.
2017-10-26
CoreyB10
Flight distance : 1665023 ft
Do not do this. Only calibrate when you are asked to by the App. The older DJI drones told you to calibrate when you changed location by a good distance but no need for the new breed.
2017-10-27
RedHotPoker
Flight distance : 165105 ft
I don't calibrate before every flight.
But if I had, it's because we moved 200km or more between our last calibration and now.
If you get a bad calibration always doing it, and try to fly, you will forever regret it...
RedHotPoker
2017-10-27
Dockater
Flight distance : 139649 ft
If you believe broken glass and black cats are unlucky then you should do a compass calibration before every flight, just in case.
2017-10-27
