Short Range
1855 21 2017-10-27
fansb0cab548
Flight distance : 337733 ft
I can only get about 600ft distance before I get "weak image transmission" then i get "disconnect" but I still have control of the drone. screen is also blank. I have tried in different areas but I am in a college town so that may play a part in it. what's your thought?
2017-10-27
ALABAMA
Flight distance : 10442687 ft
You're amongst a lot of company.  What phantom is it?  I'm guessing P3S.
2017-10-27
fansb0cab548
Yes it’s P3S
2017-10-27
ALABAMA
Try a less congested area, with less trees and structures.  It may help some.
2017-10-27
Cyril Murat
Flight distance : 455558 ft
I had almost that range with the stock P3S. Max about 900 only.
I went for a range extender kit that was fantastic. I went to more than 3200 ft without any week signal !!!
I also increased my downlink power with Magic Power Mod and I made easy FPV flights with googles quite far with no problems.
Link to the tutorial
The P3S is really great that way
2017-10-27
fansb0cab548
I did magic power mod but I didn’t change the downlinki wil do that today @cyril Murat thanks!
2017-10-27
fansb0cab548
Can I increase downlink without a mod to antenna? @CyrilMurat sorry I’m a noob
2017-10-27
Genghis9
Flight distance : 961 ft
Folks
Check this thread out, it might help, at the very least educate you on some things...
https://forum.dji.com/thread-39021-1-1.html
2017-10-27
DJI Susan
I would recommend you change to another location without interference and check again.
2017-10-27
Cyril Murat
fansb0cab548 Posted at 2017-10-27 10:19
I had a little benefit with a parabolic extender, but it wasn't extreme...
I had doubts before trying the mod to antenna, but in regard to the drone's price, the ratio value/€ is fantastic...
2017-10-27
Cyril Murat
Also : I use Litchi app and I think that it DID increase the range and transmission quality.
See the following Airdata, the ranges, the Sensor Minor Signal Errors etc.
My farest flight with DJI Go and the parabolic extender.
My farest flight with Litchi and the antenna mod (I stoped going further because I was frighterend, but I didn't get any "Weak signal" message and the wifi video feedback was perfect...
2017-10-28
Betamace
Flight distance : 2133 ft
Cyril Murat Posted at 2017-10-27 09:50
Does a P3S in the US actually produce the maximum FCC regulated 27dbm wifi output? I've wondered if the P3S will adjust it's power output according to same channel and  of co-channel interference.
2017-10-28
Cyril Murat
Cyril Murat Posted at 2017-10-28 00:01
More : both flights the same day at the same place and same setup.
With DJI Go
With Litchi
2017-10-28
fansb0cab548
After Magic Mod with 27dbm I got 1100 ft but turned around because I had to run somewhere but I didn't get any warnings at all. Thanks a lot
2017-10-28
stuka75
Flight distance : 85682 ft
fansb0cab548 Posted at 2017-10-27 10:13
Magic power is only for CE areas. US already has max wifi setting. 27db something or other.
2017-10-29
Bqnet
Flight distance : 189715 ft
After 6 month of no problems , I was getting weak image AND short range 400 ft in same area Ive always flown in.
2017-10-29
Bqnet
After 6 month of no problems , I was getting weak image AND short range 400 ft in same area I've always flown in. *EMU calibration fixed Video, *still having range issue, reset / re-link controller did not fix . Ant Mod gave me 500 to 600 feet. Before the problem started I Was getting 2000 with just a reflector on the ant. I Next may try a down grade on firmware.
2017-10-29
Betamace
Bqnet Posted at 2017-10-29 15:33
Please reply in this thread your results after downgrading the firmware. If possible state the RC and aircraft FW versions you use.
2017-10-29
Geebax
'I have tried in different areas but I am in a college town so that may play a part in it.'
The important thing here is 'college town'. Any decent college has enormously complex WiFi systems, not to mention all the students with their phones, tablets and laptops. All of these are competinbg withg the P3 Standard for radio space, so it is inevitable that the Phantom will lose out.
2017-10-29
Bqnet
No Joy on down grading the firmware, This was on my P3S. I purchased a new (used) controller.  I am back to 2000ft  No issues.   It seems the Controllers electronics, was damaged at some point.
2019-1-5
fans29803e16
Maldives
Rc signal lost in short distance
2019-3-13
Peterx
Flight distance : 1499708 ft
What FW and Go app version is on your system? And what altitude and distance was your bird during signal loss?
2019-3-13
