rodger
Flight distance : 20145135 ft
Not bad, fortunately, it happens, I tend to watch the Inspire once I set the angle of view and let the camera do its thing. If I want to make a change I go into a hover and make my adjustments and then on with the flight keeping my eyes on the Inspire.
I would go for Bob's suggestion with the epoxy. I would put some vaseline at the joints of the two connecting parts so that they do not become a permanent attachment and then when the parts free up replace the arm. If you fly to much the way it is the vibration will probably extend the crack. The epoxy should cure that? Good luck and happy flying. |
